I have a few more updates to my project.
Thanks to Joe on the STF I now own a nice scat degree pulley with Edis wheel mounted... Thanks Joe!!
This will be added to my growing stash for EFI.
I had some time this week and my order showed up in the form of some o-rings.
So I used some ingenuity and whipped up a jig to to seal my 34 pict carb for a blow thru....
Found a bit of 3 inch angle and measured high enough to hold the carb throttle shaft in the vertical position which ended up being 2 1/8 inches from the bottom of the angle.
Drilled two holes as close to parallel as I could get with the tools at hand.
Mounted the carb and checked for square with a drill bit that fit snug in the shaft bore.
Close enough..
Found a bit that matched the outer diameter of the oring to be used to seal it and drilled just enough material out to leave a depression for the oring to sit without too much drag or making the shaft too tight. It takes a couple of tries but I went slow and took just a little bit at a time and never moved the angle iron.
I could unbolt the carb and spin it 180 degrees and drill the other side with having to move the angle iron. So I just took a bit out of each side then reassembled the shaft with the orings in place and tested the fit. If it was tight, I just bolted it back on to the angle and drilled just a touch more then tested the fit again.
It is wise to tighten the nut on the shaft to make sure that you don't take too much out. I have a little bit of drag on the shaft, but the spring easily pulls the throttle closed.
After you have it to your liking, reassemble the shaft to the carb body with the orings in place and reinstall the throttle plate. At this point I have not decided whether to use the original screws and blue locktite or new screws with locktite. The only screws that I could find have a lot bigger head on them if that will make a difference or not.
On to the fuel pump shaft.
I puzzled over this for quite a while and ended up doing it like it was mentioned on the 34 pict turbo thread.
I happened to score on a real nice drill press last fall at a swap meet and it is coming in handy now.
Again.... using the angle iron as a guide I needed to make a tool rest for the shaft at 7/8 inch down from the top of the pump shaft in order to fit between the top of the bakelite guide and the oil hole below the base in the bakelite.
I used the depth guide on the drill press to get the 7/8 inch....
Then I used a new hack saw blade to cut the groove in the shaft.....hey you!! Don't laugh...
.. like the thread said.. it works!!
I set the speed of the drill up a bit so it was spinning pretty good and then proceeded to slowly remove material out with the blade. The angle iron gave me a rest for the blade so I could hold it without wandering around on the shaft.
I used a small triangle file to taper the two edges a little bit to make the groove a little less sharp. Check it with an oring to see how deep to go, then cut a little more.
Even tho the oring is very small, it seems like you will cut the shaft in two....
Test to fit... I made it work with just a bit of force to push the oring into the bakelite. Once it is inside it should slide fairly easily.
the last pics suck.. poor lighting...
.. Here is the shaft with the oring on it.
I want to make sure that I take no credit for this idea... this modification was originally posted by Mike Thompson who came up with this idea as far as I know.
I just used his thread to do my mods.
Please thank him for all this wonderful info that he so freely gave.
Thank you Mike for your great post..... it made it easy for me.
Clonebug
