Page 2 of 2
Re: A Collection of How To Do Threads
Posted: Fri Nov 30, 2018 11:32 am
by Ol'fogasaurus
how I bent brake lines.
I've bent more than a few brakes lines in my time with different levels of success and failure. I've bent some by hand, some using bending tools with different levels of success there too. In about 2005 a friend who used to own a NAPA store suggested using this tool (https://www.napaonline.com/en/p/BK_7769219);. Each of the bending dies will handle two different dia. tube and are marked as such. Each half of the dies are used for each dia. tube bend.
You still have to be careful and go slow but I got some good bends out of the tool. Some pix:
From the MC's: Hydraulic clutch and brake lines.
Through the firewall using a home made mount for the connectors.
This shows the join to the turning brakes. The tube with the join block will go into the turning brake cylinders and the tube with the plug at the end is for the brakes on the right hand side.
This shows the tube for the right side of the car going through the rear crosspiece and into the block.
This shows the driver's side clutch and brake lines going through the rear crosspiece and into the block.
This shows the rear clutch line and the soft pivot line for the rear brakes.
This shows the hard line to the rear brake block.
I you wondered about the goodie on the blocks they are for the rear brake lights but done differentlyy. Each block will tie into the brake light for that side so when you pull the turing brake handle that side brake light will light up. You hit the brake pedal then both brake lights will light.
Posted: Wed Sep 20, 2023 3:18 pm
by david58
You made any progress on this?
Posted: Wed Sep 20, 2023 3:19 pm
by david58
Have you made any progress on this?
