converting baywindow to wide 5 question.......HELP!!
- Jadewombat
Re: converting baywindow to wide 5 question...
MkV GTI/GLI Detroit rims
Those would look awesome on a Bay.Jadewombat wrote:MkV GTI/GLI Detroit rims
(Or most anything else)
mattography
Some of this may help in what you’re looking to do. The Vanagon is also 5x112 and these may help in finding the correct Wheel Nuts, Wheel Studs and Wheel thickness
http://www.thesamba.com/vw/forum/viewtopic.php?t=203519
http://wiki.club8090.co.uk/index.php/Wh ... ive_wheels
- TexasAirCooler
Yes, but what is the back spacing on those?Piledriver wrote:Those would look awesome on a Bay.Jadewombat wrote:MkV GTI/GLI Detroit rims
Terry
'65 13 window deluxe bus • restore project
mattography
slammed73hightop
""CLICK ON PIC FOR LARGER VIEW""
so this is my bus (after a full air suspension and 5inch narrowed beam is installed) and those are the wheels i found for her, they're 18's (5x112), they do come in 17's but not the 5x112 bolt pattern.they have a 40 offset. so what am i going to have to do to make them fit properly?the wheels are 7.5 wide, will that be a problem around back, with rubbing at all?
mattography
Chris V
I've got 17x7.5's on my bus and it's been tight even at stock height...I don't know what problem arise when lowered...slammed73hightop wrote:...the wheels are 7.5 wide, will that be a problem around back, with rubbing at all?
With 235/45's no problem, with 235/55's I had to run a ~8mm spacer to get the tire off the springplate in my case...and there's approx. zero room between the fender
http://img.photobucket.com/albums/v212/ ... 010040.jpg
http://www.joesracing.com/
Son of Marc
Son of Marc
- Jadewombat
Well, I found out something new yesterday about Mercedes rims. I'm running 16 inch CLK rims on my bus here. I have no issues of the hub not being big enough for the dustcap/axle nut, etc. which was asked about.
I'm also leasing an '09 C300 Sport that comes with 17 inch rims.
I was curious to see if the 16s would fit on the C300, yes and no. The bolt pattern is the same, the rims don't bind on the calipers or anything, but the hole size is different. This is the first year from what I can tell that Mercedes has done this. I spent quite a bit of time swapping over to smaller studs on my bus I put up earlier in this post. The 'new' models take a bigger lug, 14 x 1.5mm. Does anyone know, is this what bay buses and vanagons use??
Moral of the story, just because the bolt pattern is the same, 5x112, doesn't mean it'll simply bolt on.
Chris V
Yes, 5x112 Bays and Vanagons are M14x1.5...
Audi uses 5x112 M14 studs...just with smaller hub-centric bits, so they must be opened up to fit in some cases.
It's pretty normal for Mercedes rims to be either M12 or M14 depending on the size of the vehicle...smaller vehicles, smaller studs...The advantage to MB is I've never heard of any hub-centric issues.
Son of Marc
Son of Marc
WestyPop
- Jadewombat
My '66 bus empty weighs 2800lb. A small Mercedes is about 3400lb., so no it shouldn't be an issue. Studs rarely break, remember the stud isn't carrying the load from the side, it's holding the load by 'nailing' the wheel to the hub.WestyPop wrote:Anyone see any strength issues for a loaded baywindow bus or Vanagon high top camper, in switching from 13mm studs/lugs to the smaller 12mm size? (My German Ford Scorpio also uses 5 x 112 wheels with 12mm studs, but it doesn't get loaded quite as heavily as the Westy!)
- volksbugly
Detroit gti wheels
I have a set of the detroits for sale:
originally I was going to put these on my bug, but I am doing porsche suspension now so this is going to be cost ineffective for me. Initially I was asking 1600, then dropped the price several times... I Just dropped it to 750$ Grab them now they wont stay long!
https://www.thesamba.com/vw/classifieds ... id=2049140
