I made it snug but didn't go too crazy on it. Plus, there's pretty much equal pressure coming from all around it...typ4 wrote:Dont crack that sensor, it can set up some erratic signals. Pulled out some hair once till i found that.
Mounted EDIS trigger wheel on a T4 engine (w/pix!)
- msoultan
- msoultan
Just thought I'd post an update that the trigger wheel is working nicely. I haven't had a chance to post the pictures of the welded and balanced trigger wheel, but I'll try to get the pix up in the near future.
I do seem to have a hiccup at idle once in a while, but I think that's either noise on the line or some software setting - I'll need to do some research to make sure all of my shielding is good. Other than that, I'd recommend this mod to anyone that's looking to install a trigger wheel on their T4!
- msoultan
Re: Mounted EDIS trigger wheel on a T4 engine (w/pix!)
Oh, just thought I'd mention that I got rid of the hiccup. I had inadvertently let the main wiring harness for the MS run over the spark plug wires and that was causing all sorts of sync issues. I zip-tied the harness to the roof of the engine bay and it purrs like a kitten.
