How NOT to paint your pan!
kaiser
Post by kaiser »
i did it on the inside of the pan, for grip and look. por15 gets kinda funny looking after a while. it's uv sensitive.
my entire pan (inside) had a nasty case of flaky surface rust(solid just flaky), so i por'd it and bed lined it.
my car is far from a beauty queen, justy a rusty, low bug with a big motor. lol
the underside of my pan is original and in excelent shape.
MNAirHead
Post by MNAirHead »
INteresting..
WE always hydrochoric.. clean.. nutrallize.. etch primer.. seal primer.. then 3m body shotz.
Tim
kaiser
Post by kaiser »
thats the difference with por15, it prefers to bond to rust.
bugdust69
Post by bugdust69 »
I blasted my pan, brushed on 2 coats of silver Masterseries top & bottom, then 1 coat of Masterseries chassis black top & bottom. Right now the pan is collecting junk in the garage (body is stiill off) and I've seen no issues. I've dropped parts on it, tools, boxes, etc.
Blasting is the best option to give the surface proper bite. You just can't get into all the nooks with a wire wheel or 40 grit.
Looking for April 1967 Coleman camping items
hpw
Post by hpw »
bugdust69, looks good........I am at the stage now with my pan of how to
prep it for paint...contemplating sand blasting (I can get it done for 100.00)
How did you deal with the sand that got into the tunnel?
MNAirHead
Post by MNAirHead »
$100.. I'd send it out for blasting.
turbobaja
Post by turbobaja »
If I had it to do over again I'd definately have the pan (media) blasted OFF the body before starting with this build. $100 is a screamin' deal, even if you gotta get in there with a vacuum and get out the remaining debris yourself. At least the parts that count will be clean and etched. In my case, I welded the body to the pan in a variety of places, so removal is out of the question.
That's a beautiful pan there bugdust. Looks like a real clean job. I'm not familiar with Masterseries products, but they look nice :D .
I've used POR 15 quite a few times, I'm impressed with it's durability. I've seen the sun fade this stuff before too like kaiser pointed out. Otherwise it's great stuff. Good to know it can be sanded and top coated.
Karl
DON'T QUIT
bugdust69
Post by bugdust69 »
I tried to keep as much sand out as I could but quite a bit got in anyway. I stood the pan up on each end and flipped it over and blew air through it each time.
I blasted mine myself. I'd pay to do it if I had it to do over again.
Check out www.masterseriesct.com
It's comparable to por but half the price.
MNAirHead
Post by MNAirHead »
I charge $450 to prep and paint a pan + paint supplies.. your $100 is a steal.
turbobaja
Post by turbobaja »
Well folks, I'm doing my best to make this a success story. I managed to get a few things out of the way with the build while it's been upside-down for the last few months, now it's time to finish where I left off with the pan. I've been smoothing the nose into the body with some Polyfill flexible body filler and have got all the seams sealed up good and tight. The Epoxy primer and Raptor truck bed liner are going to add quite a bit of thickness where it's applied, which will create problems with fitting things back together easily. So, I masked off all the important contact surfaces and painted them with a Krylon Rust Tough Enamel product for minimal buildup.
Next step is to mask over the areas I just painted and start final prep and masking for the complete underside of the pan/body. If I can get my butt in gear, I might just have it painted "in a few days". Quite possibly our last window of painting weather is about to hit, I've got to make the best of it.
Here's some pics of the progress so far:
Karl
DON'T QUIT
turbobaja
Post by turbobaja »
The deed is done! I finally got my pan painted! What a pile of work it ended up being. I took 4 days "vacation" last week after the holiday to try and knock this pan job out for good. I worked on it about 8 hours each day, for six days straight, and just finished up this evening about an hour ago. My finger tips are raw from sanding all the little cracks and hidden areas. Then all the cleaning and degreasing untill the rags couldn't find any more dirt. Finally it got masked off and cleaned one last time.
Then I got my small detail gun cleaned and ready, and mixed up my first batch of epoxy primer/sealer. It has to sit for 30 minutes after mixing to get the catalyst going. After a few practice shots I dialed in a small spot pattern to reach into all the hard to reach areas. I was affraid the small tip (1.1) would be a problem with the primer. It calls for a 1.4-1.6 tip size. It ended up working fine, just took a little longer, which was expected with all the 'trim' work that had to be done with the small gun. Once there were only large areas left to coat, I switched to a larger gun (and cup) with 1.4 tip, it really layed down the primer nice over the larger areas. I mixed up the second batch of primer and repeated the process of small gun, big gun. Total of 3 pints (2 pints primer to 1 pint catalyst) of material were used on the 2 coats.
I waited about 90 minutes before starting with the urethane Raptor bed liner. This stuff comes in 4 bottles with 750ml of bed liner in each bottle. One bottle at a time, 250ml of activator is added and mixed well. Then thread the bottle onto the gun and go to town. Getting this stuff into all the hard to reach areas was pretty tough. But coating the surfaces that matter was easy and fast. It took all 4 bottles to get the job done. I gave the first coat (3 bottles) 1 hour to cure so I could get a bite to eat. The last one was done almost entirely on my knees, so I could see up into the areas I'd missed standing up. I'm sure I'll find a couple missed spots once I flip the body back over.........but I hope not.
So, there it is........coated.......done! I've got a few hours of carving off masking tape, trimming edges, and cleaning bolt holes before it's ready to flip back over, but basically....
The End :!: :D
Karl
DON'T QUIT
hpw
Post by hpw »
Very nice :!:
dstar5000
Post by dstar5000 »
Nice JOB and also love that rotisserie!
:lol:
Don
Glad to see you got this pan done now get back to work I want to see your car done. :wink:
turbobaja
Post by turbobaja »
david58 wrote:Glad to see you got this pan done now get back to work I want to see your car done. :wink:
Thanks for the whip crack ! :lol: .
After only getting this far in 6 years of "building", I need a little motivation from time to time. I feel like I've got a nearly complete baja-in-a-box: assembly required! Once the body is done it should come together ~easily :roll: .
In the mean time, I'm finding more things that can be done easier up-side down. The cieling and foot well area are easy to get at like this, so I'm getting them cleaned up for painting now. I've also got the fenders mounted up for a little trimming and possible reinforceing. I'll pick up some more Raptor bed liner to line the fenders with.
Karl
DON'T QUIT
