Page 2 of 14
Posted: Thu Dec 04, 2008 4:11 pm
by Leatherneck
Ido, outstanding job so far, you three are doing great. Build looks strong, only suggestion is weld the leading edges of your frame horns and If at all possible run a brace from the horns to another frame piece to keep the tranny and engine from wagging .Thanks for showing this build to us, you have any questions just let us know, we would be proud to have a long range hand in this build. What engine are you going to be using as you might have to shorten the tranny shaft.
Posted: Thu Dec 04, 2008 4:28 pm
by ido vw
Leatherneck, our plan is to weld pipes that come down from the cage and to weld them to the frame horns, to make the frame horns stronger.
and on the top of the trany there is two holes, i'm thinking about using a plate and drill a holes that fitt to the top of the trany holes, and weld two tabs to cage to bolt on this plate and to make all of the rear chassis stronger.
we already bought a engine, nice one.
I'll transfer the pictures from the other computer and post it.
Posted: Thu Dec 04, 2008 5:51 pm
by perrib
Thank you for posting here. Welcome to STF. Sasha had true friends.
Posted: Thu Dec 04, 2008 9:57 pm
by tikotiko
thats coming out real dope. that means good in california :D
Posted: Fri Dec 05, 2008 3:14 am
by ido vw
thank you everyone for your posts,
more pictures from the last month
the engine, ej25 turbo, come off from subaru WRX 2007.
the engine with bigger turbo and made almost 300hp.
the wiring
Posted: Fri Dec 05, 2008 12:54 pm
by Joxracing
Wow :shock:
Is this your first baja build?
Posted: Fri Dec 05, 2008 1:33 pm
by ido vw
yes, it is. and i'm sure it's not gonna be the last one.. :)
Posted: Fri Dec 05, 2008 1:38 pm
by Joxracing
i have a really hard time beileiving this is your first baja.
it looks like you guys been at this for yearss. :shock:
Posted: Sat Dec 06, 2008 5:11 am
by bajaherbie
where are you ordering your parts from?
and good luck with that wiring :shock:
Posted: Sat Dec 06, 2008 7:00 am
by ido vw
we was ordering somg of the parts from mkcenzies but after few troubles with wrong parts, and bad service, i decided to order the part from Pacific Castoms, chorco vdub.net and cip1.
Posted: Sat Dec 06, 2008 8:00 am
by Leatherneck
Ido, who is doing your wiring?
Posted: Sat Dec 06, 2008 9:15 am
by ido vw
the wiring will be treated by the same one who takes this engine off from the impareza WRX and convert it to STI with all the STI wiring.
he know about every wire assignment in this wiring.
sorry about my english..
Posted: Sat Dec 06, 2008 9:19 am
by Leatherneck
Is he going to keep it basiclly stock or use a aftermarket ECU? Don't sweat the English, your doing great.
Posted: Sat Dec 06, 2008 9:20 am
by david58
I have no problem with understanding what you are saying, your english is very good. :wink:
Posted: Sat Dec 06, 2008 9:24 am
by DesertGuy
ido vw wrote:we are not a vw shop, just team that build this car to the memory of are friend and some kind of amateurs.
Hmmm, amateurs? Looks like you have everything well in control... You guys are serving the memory of your friend very well, keep up the great work.
