Kevin,crvc wrote:How did you get to old luggage tray out? I planned to cut the old one at the top where it bends over but from your photo it looks like you got yours out all out in one piece. Are there hidden spot welds somewhere? Much of mine is rusted to the point it's not connected to the wheelhouse anymore.
Kevin
Believe it or not, I used a wood chisel to break the welds around the wheelhouse. The top , where it bends, has a bunch of spot welds that you can drill out from the engine compartment.
As for the front, where the tray meets the cross member, I used a spot weld cutter.
All in all, it's not that bad to remove, just take your time
You will need grind or cut some welds that the factory made in the upper and lower corners of the tray.
Take your time, you'll get it
pete
