Adjusting my Valves
- Leatherneck
- scott the viking
Yes that's fine..the way I explained it..is NOT the way I do it...I just thought it would be easier to understand if he did not have to worry about TDC and which cylinder is which. Not that I am saying he would find any of that difficult...sometimes things make the most sense when put in the simplest terms.subybaja wrote:...and since we're on the subject of cheating...
Going with your theory of anywhere on the base circle, Scott, how about this:
Set to TDC. One side will have one valve depressed and 3 free, the other side will have 3 depressed and 1 free. Adjust all 4 free ones. Turn engine over. Depressed/free will be reversed. Set other 4. Done.
Sound OK?
- Leatherneck
- MNAirHead
I'll be bold..
If you own an aircooled and will not adjust your valves... you'll damage your engine...
DO NOT let a shop do it.. they normally do it wrong (truth)... most shops do not pay the same attention you'll do.
The BugMeVideo #1 is maintenance.. will walk you step by step through the process and cost less than an hour of any shop's time.
T.
T.
- scott the viking
Well...to tell the truth...I don't really have a set "method". Normally when I am adjust my valves...I am doing something else at the same time...So the way I do it probably changes every time I do it...here is what I normally do. I peel off both valve covers (that's important)
I hook up my remote starter switch, I have my feeler gauge blade in one hand...I bump the starter with my switch until the majority of the rocker on the side I am on are on the base circle and then I run my blade under them. If it fits snug..like I can feel drag...I don't adjust, if it goes in and has room to spare, I adjust. So...I guess what I do is just bump the engine and adjust as each is on the base circle of the cam. This is probably not the way a guy who has never adjust valves should do it, just works fast for me. By the way...I can normally get quite a bit of running before the need adjusting...might be the rollers...might be the Amsoil.
- turboblue
How about saying don't let most non VW shops adjust your valves.MNAirHead wrote:I'll be bold..
T.
We adjust valves on a fair amount of VW engines and I think we have it down..........
- david58
The name of this post should have been Adjusting Valves by the Book
I do agree with doing it this way I never follow directions. I never I mean never go somewhere and return the same way.
- MNAirHead
- turboblue
- MNAirHead
maybe I could explain for a second... West Coast shops commonly just blow through these in volume...turboblue wrote:No harm, no foul Tim.
Just needed a little clarification.........
Places east of Arizona many times teach newbies to do tune ups.. chances are a valve setting may be the most important thing done to a bug.
Valves are one of the most important topic that most folks don't pay enough attention to.
THANKS for catching this ... unfortunately I replied 1/2 way from reading 1/2 the post.
Tim
- david58
fortyeye wrote:You might want to take a look here: http://www.shoptalkforums.com/viewtopic ... t=pushrods
Lash for AL pushrods and CM pushrods isn't the same due to expansion rate differences.
