well you see, what you do, is go out and buy a very strong cv joint, and then you turn down the outside of it, as far as you can, this makes it considerable weaker, but it should last longer because it will dissipate heat better. it also weighs about 1.5703 lbs lighter, so times that by 4 and you have 6.2812 lbs. that will give you greater throttle response, and add 8.34 horsepower. or, you could save yourself some time and money, and just fill your tires with helium
takotruckin wrote: turn down the outside of it, as far as you can, this makes it considerable weaker, but it should last longer because it will dissipate heat better.
So you just tossing BS or is there anything to this?
To make your car 548lbs...it is the only way to go.
Actually...the weak spot will still be the cage...so it would break before that did. In other words...it would not make it weak enough to give you any problems that a full one wouldn't.
So how much can be taken off ? Looks like 1/2 way through the bolt barrels to me. See guys the way I figure it the more I take off the rail the more I can weigh, kinda equals out ya know.
Ive looked at that before, planning on doing it to my 930 joints this winter. All claims are that they dont break there... Im just trying to stay under 1000# with my toy!
