I did get the fenders worked over pretty good though. The head and tail light cut-outs got done and the edges of all 4 fenders got a couple extra layers of glass. Also added a couple ribs to stiffen up the rears for fender mounting the lights.
The temps have been dropping lately, so I wanted to leave the fenders mounted up until I could get the garage heated up into the 70's for a few days to ensure a good cure on the fenders. With the fenders still on the body, the flip was a little more tricky. After a couple hours of knot tying and sweating, the body was resting right side up on some jack stands once again
I also mounted up the taillights real quick to see how my guess at mounting angles turned out. I mocked up the rear fenders on my work bench with a few cardboard boxes to get an idea of where/how to mount the taillights. I made an aluminum stencil to slide around on the fenders to see where the contours matched best and were the lights would appear to be vertical. The lights are mounted with a rubber gasket to help contour to the fender and clean up the edges a bit.
While I'm in glass mode I'm going to get some work done on the hood and the dash before I move on to painting the interior..........and eventually the body
