Anyway, the pictures. The WRX five speed with Quaife gets introduced to engine.
The forest of jackstands as positioning is worked out. Most 914's that go onto jackstands stay there. Not this one.
The WRX transmission axle outlets are a little closer to the flywheel than the 901, which meant the engine had to be moved back to keep the axles aligned with the stubs.
Flipped manifold. Enough space in there now for a Subaru EZ30 six, easy. Still needs detailing of course, but first things first.
But moving the engine back meant he had to box a small part of the rear trunk. That's OK, this car isn't for hauling luggage anyway. Or lawn tools. Or groceries.
Cable shifter at the transmission. Beautiful work.
And inside the car, the modified MR2 shifter. Feels notchy, accurate, and good, which is what this is all about. That and more strength, especially in first where the Porsche 901/914 transmission can't stand much torque.
A video of the shifter, still in the prototype stage, showing the action in the front and the rear:
Ask Abby what she thinks of Grandpa's car. She likes to show off those pretty new teeth.
The water-air intercooler. It will go just ahead of the engine on the driver's side.
In the car you can see part of the new cradle, just tacked for the moment.
Axles are aligned.
Business end, seen from the rear. It looks so good we'll probably go without a valence, this stuff has gotta be seen. I can't wait until in the rearview mirror I see another 914 guy who's pulled up behind and is trying to figure out what all happened back there.
It was a monster before, but you had to be real gentlemanly with the shifter. To hell with that. I can't wait. The other part of the project is the water-air intercooler. This is where we started, with the WRX engine conversion already done (which was also 55superbeetle's work):
The intercooler didn't have enough airflow there. One thought was to put a scoop on the bottom of the firewall, forcing air up, and if we found out we needed to we could compliment that with a ducktail spoiler at the back of the roof to create some low pressure over the engine lid, plus fans, of course. But wait a minute, take a step back and think how silly that is, to do all that just so you can put your radiator in that particular location, where it will still probably only work half-assed anyway. So Jeff's solution was to just put the intercooler radiator in the front in its more natural location. Done and dusted. Better aesthetically and more functional as well, so win-win.
This is where it will be, cute little thing, hidden in front of the engine radiator in the front of the car. An engine radiator where we originally had the air-air intercooler would be even more problematic.
The new intercooler layout:
Seen from car level:
Quality of Jeff's work is unmatched. If you're curious there are a lot more pictures of this transmission project, the engine cradle, what the car looked like with just the WRX motor before these changes (and more pictures of that beautiful granddaughter) in an album at: http://photobucket.com/Corinthiano
This is a work in progress, more later.
