Need BMW Bearing Part number
Schrauber Jan
Post by Schrauber Jan »
need for a Crank Swap to the WBX Crank in a Type 1 Case the BMW Part Number for the Mainbearing!
Please Help!
can´t find the Thread back!
Thanks!
Jan G.
Re: Need BMW Bearing Part number
Welcome to the STF Schrauber Jan
Check with nsracing that is his screen-name he does those conversions. Click his name and it will take you to his profile, then shoot him a PM.
Stripped66
Post by Stripped66 »
Berg, Jaycee, and VW Parts Unlimited all carry this bearing. The problem is you still need a thrust surface. I would suggest machining the case to use the late 2.1L wasserboxer hardened-steel thrust plates.
