2276cc,AS41 case,mahle B+Ps,FK89,comp elims,50mm throttle bodies running off a flywheel triggered EMS ecu,48LB injectors,11.9:1 compression on e85 fuel,2" jee cee header and home made stinger.And a 30hp shot of NOS,made 233bhp on the dyno 2 month ago
Gearbox is a rancho pro drag,not sure on ratio's(i go over line at 115-120@7800rpm in 4th).
Race alxes,and set of AVO coilover (180lb springs) on the rears.
Ali front beam with bugpack shocks on front
STOCK BRAKES
drums all round,even still on single circuit
RLR cromo full cage,fitted by daz @Aircooled Performance.
Little vid to....
