Mounted EDIS trigger wheel on a T4 engine (w/pix!)
msoultan
Post by msoultan »
Hey Everyone,
Some of you might have seen this method for mounting a trigger wheel on a type 4 engine:
http://www.shoptalkforums.com/viewtopic ... gger+wheel
I was going to do that, but I stared at all the pieces a little bit longer and found a different way to install things. The other way will work, but my concern was trying to get the trigger wheel lined with the sensor and not being able to see the gap because the fan was in the way. The way allows you to install the sensor and wheel and verify that everything is lined up and then install the fan.
What I did was take an old A/C pulley and milled down the OD until it had an 0.007 interference fit with trigger wheel. I heated up the trigger wheel, cooled down the pulley, and once everything was lined up, I pressed 'em together;you'll notice that I only pressed the trigger wheel onto one side of the pulley. As for the sensor, I cut off the mounting ears and bent a piece of aluminum to squeeze the sensor against the housing. I made the holes in the aluminum slightly larger than need to allow for adjustment.
Here are pics of the install. Enjoy!
NICE!
I would TIG that wheel on in 3-4 spots, crankshaft harmonics happen.
msoultan
Post by msoultan »
My friend has a mig welder. Would it be ok if I tack welded it in 4 spots around the wheel? I was thinking about that, but the only reason I didn't was because I was worried it would warp, but I guess a quick tack wouldn't heat it up too much.
Normally these wheels are press-fit onto a hub of some sort - do you really think it could come off?
MRRAGPICKER
Post by MRRAGPICKER »
Pile beat me to it. At 6000rpm, I''d like some spot welds holding that together. But it may need balancing after welding.
If that comes off at speed, it will lodge in the immediate area and jam your crank in a millisecond, grenading your engine.
msoultan
Post by msoultan »
Ok.. that's easy enough. I'll spot weld it up and bring it to the shop to be balanced.
Thanks!
Mike
msoultan
Post by msoultan »
do you guys think I'm going to run into any temp issues in regard to the location of the sensor? It's not under the airflow of the oil cooler, but it is next to it..
MRRAGPICKER
not sure about the heat at that point, someone else will know. I was just thinking, is that toothed wheel Alum. or steel. To weld it, it needs to be the same material as the hub you pressed it on.
Tom Notch
Post by Tom Notch »
But 1st, and most important, is............................... :idea:
.......it would need to be magnetic :idea: :lol:
which means its probably steel. :wink:
MRRAGPICKER wrote:not sure about the heat at that point, someone else will know. I was just thinking, is that toothed wheel Alum. or steel. To weld it, it needs to be the same material as the hub you pressed it on.
Ilike this method, its gives me an idea or two. :)
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
I suggested TIG as the existing bits would basically be melted... together, if it's a press fit, no additional material should be needed.
Having them balanced wouldn't be a bad idea, but if they were balanced before and were cut true, and no additional material is added...
msoultan
Post by msoultan »
I think it's steel - a magnet sticks to it...
davebuckholts
Post by davebuckholts »
How secure is the sensor mounted? I would be afraid of movement of the sensor, but I'm not that well versed in setting up a trigger wheel. Is there any fudge factor if it moves some?
MRRAGPICKER
Tom Notch wrote:But 1st, and most important, is............................... :idea:
DUH, I wuss thinking to much about it, and forgot about the magnet.
msoultan
Post by msoultan »
davebuckholts wrote:How secure is the sensor mounted? I would be afraid of movement of the sensor, but I'm not that well versed in setting up a trigger wheel. Is there any fudge factor if it moves some?
That thing's not going anywhere - it's a pinch fit between the shroud and the aluminum bracket and there are two nyloc nuts on there...
typ4
Post by typ4 »
Dont crack that sensor, it can set up some erratic signals. Pulled out some hair once till i found that.
2840 type4, turboed and injected with my GM conversion. runs great and still needs fine tuning.
didget69
Post by didget69 »
Nice! It seems that there could be a market for some enterprising individual with a lathe to jump into production of EDIS trigger wheel adaptors with a VW T4 center hub, so that it could be installed like the version here? I've been looking a T4 A/C pulley for quite awhile - Nada...
bnc
