Front turn signal lenses for 411 fit 412?
- MGVWfan
Howdy! I'm back again! I've got a crunched LF turn/park signal lens on my '73 412 wagon, and was wondering if they changed the fronts between 411 and 412 so the older lenses won't fit on the later model. The lamp housing p/n starts with 411, so at least there's no specific wagon p/n (would be a 461 in that case). I have a set of lenses coming with a 411 p/n, they look the same...Ray:?:
Lane
73 VW 412 (the Nomad, dropped valve seat land now, argh!)
67 MGB (Abingdon's Finest)
76 Plymouth Duster /6 (runs like a top)
99 New Beetle 2.0 (never gives any trouble)
04 Golf TDI (45 MPG)
09 JSW (love it, love it, love it!)
front turn signal
hy,, MG,,have you need the lefgth turn signal,,i have 6-7 in a box,, i have for the 411-and412 i d,t can reemember if they are for the r,or lefgth side but i can look if you want,,albert
- MGVWfan
Yeah, I just got a set that looked right, but were too long.
Oh well.
Albert, the left front turn signal lens on my '73 412 Variant measures 20cm ALONG THE CURVE at the top, and 19.5cm along the curve at the bottom. Top and bottom are curved. The front edge is 7.5cm, and so is the back edge. If you have a left front turn signal lens like that, new or used, please let me know, and merci beaucoup!
Anyone have the VW PN for the L and R front turn lenses for a '73 412? I have the 411 PN's, so maybe we can put together the list and post it in the sticky area.
Thanks for the picture Bill K...the one on top does look the same as my '73's front turn lenses. The one on the bottom is what I have in hand now. Anyone need some "long" front turn signal lenses?
Lane
front turn
hy,, MG,, i geeve you the list for the 411-412 lens ,, front and rear,, nex week wend i found the box,,,albert
- MGVWfan
- raygreenwood
- MGVWfan
Unfortunately Ray, there is no p/n on the lenses...there is a DOT number, TVM8, maybe that means something? BTW, I've had a great response to my feelers, I've got another lens coming in that is confirmed correct...I do appreciate your kind offer.
If I hit another brick wall, I'll PM you for help.
Lane
- MGVWfan
- MGVWfan
I think CH# 410xxxxxxx is 1970...the 412's would be 412xxxxxxx (1972) at the earliest, assuming late 1972 production for 1973 412's, or more likely, CH# 413xxxxxxx. I don't remember if the CH#'s go by calendar year, or model year (starts in August)...hmmm! My August 1973 production 412 wagon CH# starts with 463, as an example.
Lane
- MGVWfan
Ah, that is good info, thanks! I'll put it on the sticky post I started on front turn signal p/n's.
Lane
- ubercrap
Re: Front turn signal lenses for 411 fit 412?
Sorry about the dredged thread, but here is the above mentioned "D" series lense for sale: http://www.thesamba.com/vw/classifieds/ ... id=1220902
Notice the different "grid" pattern (naturally). Is this the same profile/contour as the ones in North America? I think there are some that are flatter/lower profile, but maybe those are all the clear Italian type? I can't recall now.
