091 gearbox lsd diff
Passatman
Post by Passatman »
Hi Bruce you wanted to have a look at the inside of my diff i am going to use in my 091 gearbox. well here is a look.
Bruce2
Post by Bruce2 »
That is very interesting. Does it have any casting numbers or symbols?
Passatman
Post by Passatman »
WELL THE MARKING ARE AS FOLLOWS.
Sl
hale
b 624
151510011
Don't know if this helps.
Bruce2
Post by Bruce2 »
Any VW logos?
Passatman
Post by Passatman »
none.
ngobet
Re: 091 gearbox lsd diff
Post by ngobet »
I bought a similar diff, does anyone know what it is? There is a preload system on the side gears.
Numbers in the casting are:
SL
Hale
B 324
15 15 100 11
Passatman
Post by Passatman »
ngobet i think we have stumbled upon the positraction diff. If this is the case and i think it is we have struck gold here. I am going to look at mine in detail on the Christmas break. I have a bore scope camera so i will be taking internal pics.
Passatman
Post by Passatman »
Unfortunately i couldn't get the borescope camera pass the opening in the diff but this is what i got.
https://www.thesamba.com/vw/gallery/pix/1983907.jpg
ngobet
Post by ngobet »
interesting, it is possible that it has the same internals as the Peloquin positraction type. Like on that page: https://www.gowesty.com/product/automat ... ferential-
There is no way that there is space for the spider gear / side gear assembly with the disc clutch type LSD in that housing, it looks the same as our diff.
Mine came from a workshop where they used to rebuild swiss army vehicles in the 80s-90s, it has to be a factory part.
I bought a bunch of LSD together and the rest is all factory ZF. Will have to research which LSD option was available for 091 back then
Passatman
Post by Passatman »
Yes i want to think that this is indeed a posi-traction diff from a military vehicle. I now need a 5speed 091 kit to build around this unit.
ngobet
Post by ngobet »
I finally opened that diff and made a post to show the internals
viewtopic.php?f=50&t=151546&p=1281916#p1281916
