Is there a specific fuel pressure gauge that I can use for my 411?
The reason I ask is that on the steel part of the fuel loop, on the left (driver's) side, I looks like there is a threaded port to attach such a gauge. Mine is blocked with a small bolt. This appears to be about a 4 or 5 mm orifice.
Thanks, guys.
-Justin
Fuel pressure
fuel pressure
hey,,weldthing,,i have use ,,a liquid pressure guadge,you have the air pressure guadge ,too ,,,but not good for the liquid,,and if it was only for a test guadge ,,i have clip a hose on ,,t,,, for the injection line ( your tred ) for a short time only ,,d,t take a chance with a permanant guadge ,,, we have plenty of gaz leak place on this injection,and take a model with a long randge ,,0 to 100 example,,and you keep that for adjusment tool afther,,,albert
