RexR Baja Build / Update Thread
dsrace
Post by dsrace »
rexr have you seen one these tube frames for the fiberglass bodies? I don't know if it would work on a baja but doesn't look to hard to build. if it would work you could build it with all the mods a guy wanted.
CopperBaja
Post by CopperBaja »
Build looks good!
Any updates this weekend?
rexr
Post by rexr »
dsrace wrote:rexr have you seen one these tube frames for the fiberglass bodies? I don't know if it would work on a baja but doesn't look to hard to build. if it would work you could build it with all the mods a guy wanted.
Just checked them out.. I don't think you could buy theirs and use it because a buggy is usually shortened..
It does look like a cool idea if your were building something from the ground up though..
rexr
Post by rexr »
CopperBaja wrote:Build looks good!
No.. It's my boys 6th birthday this weekend so I promised mama I would stay out of the garage.. :cry:
I should be able to spend some time on it next weekend though.. :D
CopperBaja
rexr wrote:No.. It's my boys 6th birthday this weekend so I promised mama I would stay out of the garage.. :cry:
I empathize.... I have a 9mth old... I really need to setup up a chair with toys in the garage, so I can get more done. :lol:
rexr
Post by rexr »
CopperBaja wrote:I empathize.... I have a 9mth old... I really need to setup up a chair with toys in the garage, so I can get more done. :lol:
Careful.. I had the same idea until my son tossed a screwdriver into a running table saw.. :shock:
Talk about crapping your pants and a major eye opener.. who knew a little kid could throw so well..
dsrace
Post by dsrace »
I found that out to. a glass buggy is usually shortened 14" I believe. I guess I will give it a try but with a-arm and 3 link rear. :) I have a full pan, I think it's a 69. link pin / swing axle. I don't know if I kept it but that bug had a gas fired heater, looked more like a bomb.
rexr
Post by rexr »
dsrace wrote:I found that out to. a glass buggy is usually shortened 14" I believe. I guess I will give it a try but with a-arm and 3 link rear. :) I have a full pan, I think it's a 69. link pin / swing axle. I don't know if I kept it but that bug had a gas fired heater, looked more like a bomb.
I have a friend that is into old buses.. He told me about those heaters and I could not believe it.. What a concept.. :shock:
Joxracing
Post by Joxracing »
what year is that from??
funbodies.com used to sell a long wheel base (stock VW) tube chassis/pan. I just looked at their web site which is in the process of being redone but I only saw wording that alluded to "your chassis."
I used to have pix of it and it looked OK. You might want to contact them, if you are interested, to see if they still make them.
I almost forgot, they also sell Baja plastic.
Joxracing
Post by Joxracing »
that pan said up looks nice and cheap....... i thought it was 1970's prices :D
the new issuse of sand sports has an article about berrien buggies and the small town they are in.....
