004 Rebuild
Discuss with fans and owners of the most luxurious aircooled sedan/wagon that VW ever made, the VW 411/412. Official forum of Tom's Type 4 Corner.
Lars S
Post by Lars S »
Yes, I can confirm one part coming straight from the 100LS to the 412: the black plastic front door baskets introduced in 1973.
/Lars S
-914/4 -72 daily driver
-Husqvarna 120cc rat bike -48
-Husqvarna 120cc -52
-BMW 600 Road Scrambler -69
-Suzuki T500 Cobra -69
-VW411LE 2-door sedan -70
-Porsche 914/4 -72
-VW412LE 4-door sedan -73
-Suzuki K50 -77
albert
004 rebuild
Post by albert »
yes for what i have see in my technical book ,, they geeve many compatible parts in the motor ,tras, and the body,, for audi,porsche and vw,, albert
raygreenwood
Post by raygreenwood »
Albert...what technical book do you have?
The interesting problem...is that if a part remains in a VW...and is used from model to model...it keeps its same 9 digit #.
Like a part that is a 311 prefix appearing in a type 4.
But...this did not happen with early audi and Porsche. You could find an exact part that originally was used in a VW...but later appeared in an Audi with a totally new part number. These are the things I want to know about.
For USA consumption...its really the early 80's audies than can help us. Anything before about 1980....is even harder to find examples of than type 4's here on this continent. Ray
albert
004 rebuild
Post by albert »
oh,,RAY,, you have the 100$ question,,first send me ,,email for the book,, secondo,, in this book that is a very long job for to find the substitute parts for the 412 ,, he has 20 section ,,and 200 + or - of page in each section,, plus that take a spécial zoom on your compuiter for to see something ,, i send you couple pages on your email for example if that can geeve you a help,, it is a micro film,, for me i put the page in my compuiter image and afther i do the transfert in my foto shop ,for the adjusment , for a betther vue,, go to look your email,,alberet
albert
004 rebuild
Post by albert »
OH RAY ,, I HAVE THE BOOK FOR THE EUROPÉAN ,,M ,,CODE,,SPÉCIAL ÉQUIPMENT FOR THE 411,, 20 PAGES,, AND I HAVE NICE PIC,,FROM VW 411 CRASH TEST TO 30 MILS,HRS,, AND MANY MORE,, I HAVE 1700 PAGES IN MY ,,CPU ,,FOR THE 411,, :roll: ALBERT
Bill K.
Post by Bill K. »
Torlon bushings with oiling grooves installed in modified countercluster. Front face (shown) of countercluster rotates CW so ID groove is on trailing end of end bevel. Other end of same bushing is opposite orientation for groove 180 degree opposed (not shown).
This is the NOS unit. The unit from the parts car was also modified for a spare :P
raygreenwood
Man that looks sweet!
I am still working on a simple method of getting more gear oil flowing through both the counter cluster gear and the differential bearings. But I do know that just the grooving really helped even with the factory needle bearings.
One thing that can really help....but has an issue...is just being able to get about 1 pint more oil into the transmission.
If you can get the oil levels to stay high...without being excessivly high and causing drag....it keeps the counter cluster submerged much better and helps keep oil going into the bearings through the oiling grooves and center oiling hole.
The problem with having extra oil is the vent hole near the rear bearing on the tail cone. It vents from there.
I will be also trying a small funnel type oil vent enclosure/extender at this location...kind of like an oil separtor box. This way, anything that vents...drains back in. As long as the at rest oil level is below the mainshaft entrance you will have no leakage. But just an extra pint of oil really goes a long way toward better operating. Ray
