Seabee turbo buggy build
Hedrock
Post by Hedrock »
Looks good to me... :wink:
perrib
Post by perrib »
Wow! Great attention to detail. Its almost too nice to drive. Arizona pin striping keeps me from having anything that nice
Are you going to sleeve it or butt weld it? Looks good, me likes, but your the one that matters.
leather is right.... might ought to sleeve and plug weld for some extra strength.
CopperBaja
Post by CopperBaja »
I like it!
Maybe some dimple die panels to take up the open space?
That would look pretty cool. Considering with that motor...and a fiberglass body, you're not too worried about weight. ;)
seabeebuggy
Post by seabeebuggy »
Yes it is sleeved. 12''. I thought about plug welding it. Was not too sure if it was a good thing or not? I need more sleeve . the other side is not aligned perfect. I put the hoop on the ground and it was almost perfectly flat But as I have one side set the other is 1'' lower. I am going to cut the rear bar and rotate it. You will never know. Except the globs of welding trails. :shock:
I was thinking of making adjustable head rest for the rear. Something to pad the heads from the fuel tank. I want to design the tank mounts at to make it easy and clean to remove it for places I don't need it. I have a 6 or 7 gal tank under the hood. Silly me did not ask for a bigger tank I just asked for a 59 fuel tank because it was a 59 pan... DUMB DUMB. :evil: I still need a large tank for the long hauls. The kids will still be able to sit in there with the tank though.
www.BigMikesGuns.com oe https://www.BMGAA.com
Thomas Jefferson said It may be necessary for a country to have a revolution every 200 years to right the wrongs of a Government.
Got Lead?
seabeebuggy
Yes some dimple dies would be awesome. I was thinking that too. ..
Got Lead?
seabeebuggy
perrib wrote:Wow! Great attention to detail. Its almost too nice to drive. Arizona pin striping keeps me from having anything that nice
Thank you....
Your in jail?
Got Lead?
Skidmark
Post by Skidmark »
I would love to own my own set of dimple dies... and the hydraulic press to use them, too! You could use a vise I guess, but a press would get you into the panel farther for the larger jobs. Hell, a 4 foot press brake in my garage would do as well... and a mill. Oops, forgot the lathe! Am I asking for too much?!
To be totally honest, I would settle for the room in my garage for tha above equipment!!! :shock: :lol: :lol:
Kraut_n_Rice
Post by Kraut_n_Rice »
Thank you....
Your in jail?
Az pin stiping is code for the nice deep gouging that all the desert foliage puts in your paint. :wink:
Adds character if you ask me. :lol:
'68 Baja project. FOR SALE
seabeebuggy
LOL ok I thought it was a strange thing to say. But now i know. :lol:
Got Lead?
CopperBaja
Kraut_n_Rice wrote:Az pin stiping is code for the nice deep gouging that all the desert foliage puts in your paint. :wink:
I agree. I'm not afraid of getting a few scratches on my baja. Just ask crisis68. :lol:
seabeebuggy
I am burning out. My frame //pan or body has never been flat or straight. I have everything even yet everything is off. If i run the rear hoop with the contour of the body it looks strange and all the angles are not the same. If I lever the back hoop to the rest of the gage it still looks off and things don't line up. Everything is bent the same or really close and the same length.. I am looking for a middle ground. the body always looks like it is leaning to the passenger side.. hummmm...
Got Lead?
CopperBaja
seabeebuggy wrote:the body always looks like it is leaning to the passenger side.. hummmm...
Need to put on a couple pounds and they will look even.... :lol:
seabeebuggy
Ya that sounds like a idea.. not.
I did find one joint that was just binding so I cut it and it pooped into place the other part was still lined up. just needed to twist a 1/16'' that is crazy small to cause so much headache.
Got Lead?
