I recently purchased a 1977 Convertible. Along with the usual rust in the floors and heater channels this one also has major rust in the cowl area. I have been all over the internet searching for a cowl replacment panel without any luck. Is there such a thing produced or will I have to cut the cowl from a donor car? Any suggestions would be appreciated.
Thank you. Do you know if the donor car has to be a convertible, or is it OK to take one from a regular Super Beetle? Mine has a large rust hole in the lower windshield channel and in the cowl between the windshield and trunk.
peryde wrote:FYI. I found that the cowl piece from a Super is a perfect fit. I cut out a cowl from a -73 super donor and I am in the process of welding it in.
Good deal! If you could, try and share some pics with us for others facing this same repair please!
