Now, i going to weld in a new front clip, replace the rear apron and some other in perfections, on my 57 oval, that the PO messed up on
pete
Post up a thread showing how to do it. Pics would be nice too.slowtwitch wrote:I started about a year and half ago. i have since welded in pans, heater channels, front and rear clips, some roof repair, on my 67.
Now, i going to weld in a new front clip, replace the rear apron and some other in perfections, on my 57 oval, that the PO messed up on![]()
pete
David, I'll definitely document my adventures.David58bug wrote:Post up a thread showing how to do it. Pics would be nice too.slowtwitch wrote:I started about a year and half ago. i have since welded in pans, heater channels, front and rear clips, some roof repair, on my 67.
pete
TRScott, I've had a HH125 for abt. a yr. Not a professional by any means, Really beginning to understand more and more wire speed and heat relation. Started out using it with the flux-core until i could afford the gas and tank. The difference using gas is amazing. I bought this for replacing the pans in a 70 Beetle.Still getting a little better to start this process, so far, love this HH125, Good lucktrscott wrote:I've done a bit of welding with an old AC/DC Miller stick welder I picked up, and I have done a ton of plasma cutting with a Hypertherm 40A plasma cutter (3/8" and 1/2" steel, cutting out welds, making tractor wheel weights). My welding has been 1/8 steel and thicker and I end up grinding a lot to clean it up, but it is strong. Stick is good for getting penetration with thick stuff, but everybody tells me stick is the hard way. and I can vouch for that, I am no expert by a long shot.
I need to get either a MIG or a TIG to begin doing some body and pan sheet metal welding. Stick is just too tough for thin sheet metal, in my opinion. I am sure I would love MIG or TIG after trying to do everything with stick.
But I don't know which I should get. I tend to lean toward Miller equipment. It would be nice to get something that could do aluminum too, but I've been told that you really want to get a reel gun for aluminum because the aluminum wire doesn't like to feed down the hose very well. It isn't stiff enough. With a feed gun the aluminum wire is right in your hand.
I would really love to hear from someone who has used both flux wire and shield gas to hear what they prefer. Cost matters too, but I suppose I will pay what it takes to get good equipment that you don't have to fight with all the time. Good tools are their own reward.
JMHO FWIW
-ts
yeahbugninva wrote:bugdust, all that experience and you failed the 6g? I stopped welding on pipe and pressure vessels about 13 years ago or so, but feel pretty confident that I could put a hurting on that coupon today and still pass.... guess it just shocked me a bit...
hahahaha... I was a welder for a living years ago, now I'm a contractor... wood is good too...um... that sounds funny...Hotrodvw wrote:I have been welding for approx. 10yrs. I kind of learned by just doing it, watching others, and a few tips from friends. I just use my Weld-pak 100. It's been working wellf or what I've needed so far, but would love a larger machine. I've always loved working w. steel. Wood is boring.
