My build up
64bug
My build up
Post by 64bug »
So i copyed and pasted this from franklinsvwwerks.com forums(my local forums.)
well after a few years of buying parts and building its time to start a build up tread...
Some info...
64 type 1
2332cc built by Tim Hancock/ Dennis from Stricky speed (thank you both)
wiescos
scat pro-comp crank (wedgemated)
cb h-beams
ceramic lifters
cb wedge ports
revmaster pump 30mm
raceware headstuds
tcs20 cam
Turbo system by Marty Staggs (on its way...)
T3/t4 stage V turbo
sds injection
water to air intercooler
csp carbon fan should
eboost2 conroller
944t brakes
Turbo twist wheel 17x7.5 17x9
Tranny built t-1 By Stricky Speed:
3.10 1.93 1.35 .89 4.12 hewland shaft
superdiff
gusseted
erco cover
saw axles/torsion bars/ adjustable plates
kafer bar
So far i'm trying to finish up the body work and paint this thing to have it together by summer.
before:
new pans:
new heater channel:
new rear clip:
Rust sucks by the way...
bare metal the car: (a million coats of paint, and bondo later...)
body work (both new lower 1/4's) Primer.
meanwhile...
And the brakes.
Quick lesson here...
2332 stroker= wide.
2332 low cr. motor = wider.
The shroud... not that wide, so i had to do a little "custom work" with a grinder...
ImageAnd heres some other misc. photos.
raceware headstuds, ti retainers, AND top secret rockers...
sds efi:
fuel:
Sooo many fitting (this is just fuel, nother box for oil...)
Raditor for intercooler:
Wide rears:
front wheels:
turbosmart bov, wastegate, eboost2 controller:
setrab oil cooler:
doors are done:
And heres a scatter shield i made just in-case the wedgemating doesn't want to hold...
2stroke
Post by 2stroke »
wow thats an awesome car
Abell
Post by Abell »
Great work!What's your hp estimate?
64bug
Post by 64bug »
Thanks 2stroke, just trying to get it done for summer.
Abell wrote:Great work!What's your hp estimate?
Enough for me...
ToRy 70
Post by ToRy 70 »
Lookin' GOOD!
I've used one of those as a motor dolly before... After the real dolly I bought decided to lose two wheels:D
Is your sump cut that way to make room for the header?
I hope you didn't thread that temp probe fitting into the setrab cooler that way...
ToRy 70
Post by ToRy 70 »
Also I heard you ordered a dizzy plug from boost engineering? I've been trying to get ahold of him for a while, my EDIS kit is sorely missed.
red74super
Post by red74super »
wow.
nice build.
how much boost you gonna run?
64bug
Post by 64bug »
Hey Tory,
Marty cut the sump to clear the header and i believe collecter. I will see when i get the header and fit it all up. (its being shipped)
and no that fan switch is just resting there so i dont lose it...
As far as boost eng. is just emailed him and then sent him money via paypal. hasent showed uo yet...
MarioVelotta
Post by MarioVelotta »
:twisted:
[email protected]
64bug
Post by 64bug »
MarioVelotta wrote::twisted:
Well when you gets yours done, and i get mine done........ i think it calls for a little NW turbo meet and greet. and race... :D
MarioVelotta
:D That would be a blast. I smell a NW dyno day :twisted:
[email protected]
racelook
Post by racelook »
Nice progress!!
Keep us posted
Wiebrand
64bug
Post by 64bug »
I got some boxes from Marty today!!!! :twisted:
Header and turbo are on there way.
Excuse the tape.. It will fit a little better when clamped and bolted together...
I am so amazed by his skills... You really cant understand until you hold it..... Haha sounds like a good pick-up line :D
MarioVelotta
I'll definatly be behind you at the track :evil:
[email protected]
ToRy 70
Post by ToRy 70 »
Sh*t's the tits! What kind of TB is that?
