Battery state of charge
- david58
Voltage State of Charge
12.6+ 100%
12.5 90%
12.42 80%
12.32 70%
12.20 60%
12.06 50%
11.9 40%
11.75 30%
11.58 20%
11.31 10%
10.5 0%
12.6+ 100%
12.5 90%
12.42 80%
12.32 70%
12.20 60%
12.06 50%
11.9 40%
11.75 30%
11.58 20%
11.31 10%
10.5 0%
- david58
This is with the engine off. The battery ideally should be dis-connected from the electrical system, because you are checking the battery and nothing else in this test.
- david58
When should it?MedicTed wrote:Actually, a 12V battery should give 13.6V.
BATTERY CONSTRUCTION
Lead acid batteries used in the RV and Marine Industries usually consist of two 6-volt batteries in series, or a single 12-volt battery. These batteries are constructed of several single cells connected in series each cell produces approximately 2.1 volts. A six-volt battery has three single cells, which when fully charged produce an output voltage of 6.3 volts. A twelve-volt battery has six single cells in series producing a fully charged output voltage of 12.6 volts.
Go to this URL: http://www.progressivedyn.com/battery_basics.html
I see 2.1 x 6 = 12.6
- Leatherneck
- Badbugtwo
- Marc
Essentially. The table David58bug posted is still a good guide (there are slight differences between batteries, so it's not gospel in any case).Leatherneck wrote:What about the optima dry cell batteries, I already bought one, but anybody have any negatives about them. And are they the same as the wet cell voltage state of charge?
A fully charged "12V" lead-acid battery will read about 13.2V before the "surface charge" is removed (done by applying a small load, ~15A, for a minute or so...conventional batteries will self-discharge to this level just from sitting for a day) after which it will read around 12.6-12.7V.
When charging your Optima, don't exceed 10A (5A is better) or ~8 hours. Don't use a charger that puts out over 15V, and if it starts to hiss take it off charge and let it cool down.
www.autoshop101.com/forms/hweb4.pdf
http://www.optimabattery.co.uk/english_ ... torial.htm
- Marc
The replacement decision would be based upon the results of a load test. With the battery fully charged (if it hasn't set idle for 12 hours after charging you should turn on the headlights for 20 sec or so to knock down the "surface charge") a resistive load is applied to draw current at ½ the Cold Cranking Amp rating (or other testing current spec if labelled) for 15 seconds. At the end of that time the voltage should still be over 9.6V (at 70°F) and the specific gravities should not differ by more than .05 cell-to-cell....that's the "short" answer - more here: http://www.uuhome.de/william.darden/carfaq4.htm#remove
Normal starter current can vary depending upon the model of starter and just how hard the engine is to crank over (compression ratio, oil viscosity, ambient temperature, etc. are factors)...for the sake of argument, let's say it's 175A. Even a cheap group 42 battery should have a CCA of 400 or so (good ones are 500-600) so any battery that passes the load test shouldn't have any trouble cranking the engine.
sagaboy
So.... it means that even though the battery state of retained charge capacity is at 12.06 V 50% "after 12 hr set idle" and as long as it can crank the starter--we can continue to use it. If this is the case does a leaky battery put a strain on the alternator trying to charge it to full storage value?
sagaboy
