my car is actually running great, with fantastic power, but my MPG on the freeway at 70 mph is only 13 the only other sign something is amiss is if i drive it for some distance and shut down for 15-20 minutes. Then, upon restart, it dies everytime i shift into gear from P. my current temp solution in that situation is to slightly rev and pop into gear. once rolling for a few moments, it idles just fine at stop lights and such.
CHT the culprit here?
Notchback mid-engine speedster Little Giant Killer 3
Check for vacuum leaks first...especially the vacuum line to the transmission....and the auxiliary air regulator. I would also check the fuel pressure. Ray
