My four year old picked the name. I picked this car up in SanDiego,CA. According to the PO it is an old retired Baja 500 race car. I have no documentation but I have never seen a cage like this in a recreational car.
There are some other clues. If it wasn't a race car someone was pretty serious about their toy.
It has rack and pinion, widened front beam with adjusters and raised shock towers, heavy duty swing arms with triple shock mounts, Sand flyer swing axle, Full tube chassis with everything tied into the cage, including the 20 gallon fuel cell and Optima battery, full set of VDO gauges, removable steering wheel, suspension seats, four point harnesses, and a full Beetle sedan wiring harness.
When I put the 16" Centerlines on the car I have 15" of ground clearance. Unfortunately one of the front rims is bent so I put my steelies on till I can get them trued up. I plan to run 31" tall tires all around.
