BTU can be converted to HPhr, because both are energy units. But a gasoline internal combustion engine can only convert 25-30% of the energy contained in the fuel into mechanical work. Engines running on alcohol have higher efficiency numbers. This offsets somewhat (but of course not completely) the lower BTUs of the fuel. If an engine is optimized for alcohol (high compression/boost, direct injection and so on), it can get about the same milage as a gas car on a volume/mile basis.Plastermaster wrote:Interesting point. But how does that pressure translate to power? BTU has a conversion factor to translate it into HP units. Also feild experience has shown alcohol to not take you as far down the road compared to gasoline (measured by volunm).
My question about the ideal ratio was in reference to using an A/F meter to help jetting carbs. Like Ray was pointing out, the O2 sensor sences when there is no o2 left in the exhaust, so that is what it is about, except for the other considerations such as CHT and what not. Its just with Alcohol the jetting required is different, since it is more resistant to being sucked through the jet. However when mixed with gas, it might not be directly proportional to the % of mix.
Ron
Regarding tuning with alcohol fuel:
Do NOT use a A/F meter based on a regular O2 sensor. When richer than about 14.1 gasoline AFR (0.96 Lambda) they are much more sensitive to EGTs than to AFR (or Lambda). Alcohol fuels typically have lower EGTs, which means a NBO2 sensor outputs a higher voltage. People have been fooled into thinking this is richer and leaned out their engines dangerously.
Use a wideband meter instead. Use Lambda as indicator and tune to about the same Lambda as when using straight gas.
