Converting motorcycle throttle bodies
Paul Illick
The machining on that adapter you drew isn't so simple, and it won't be cheap. Check cutting off the flanges of the T4 manifolds and re-welding as was suggested, which should be cheapest and still do what you need. Welding is cheaper than machining. Then use the rubber boots that came with the Suzuki TB's, simple enough.
For the linkage look at BMW R-series motorcycle throttle cables. The R's were the horizontally opposed engines with a carburetor on either side of the engine, so they used split cables. One side of the cable has an adjuster to lengthen the outside tube so you can balance them side to side. Then leave the TB pairs on each side of your engine linked and use that cable, one end to each side. Alternatively I think that some of the English performance parts places (Tweeks, Redline, etc) have split automotive cables that were used on the old TR3's or Europas or something. Or try Pierce Manifolds in Gilroy, who have something similar but automotive and probably a bit more expensive.
John_S
just noticed this thread as i've just got hold of some motorbike tb's (could be off a vmax i'm told) there 40mm in diameter , and i'm going to attempt to put em on a 2110cc aircooled engine
John
www.autoelectricsolutions.co.uk
John
With very little work, those work great on Webers as well, made my own from JY MC parts and ran them with no need to adjust anything for years.Paul Illick wrote:The machining on that adapter you drew isn't so simple, and it won't be cheap. Check cutting off the flanges of the T4 manifolds and re-welding as was suggested, which should be cheapest and still do what you need. Welding is cheaper than machining. Then use the rubber boots that came with the Suzuki TB's, simple enough.
Someone should be selling them for ACVWs.
- Wally
John_S
- slowtwitch
- Wally
Cool, thats the closest to IDF-pattern I have seen so far!John_S wrote: i've used CBR900 throttle bodies.
I must admit the difference in centre to centre between these and IDF is within 2mm
if u want pictures i can post some
John
Yes, some pics as how you mounted the TB's to the manifolds would be excellent!
TIA,
Walter
- slowtwitch
OK, here is my feeble attempt at adapting MC throttle bodies. These are Honda VFR TB's. A buddy of mine gave them to me, so I figured I give it a shot
Anyway, they are 36mm and there was about a 2mm difference, center to center, compare to Dell's. I milled the fit off center on the adaptors, 1mm.
pete
pete
- slowtwitch
Thanks 76bug,
I still have to drill and tap the mounting holes and polish things up.
As for the linkage, I'm going with a cable setup that I have been working on.
It's kinda of universal, it will work with these TB's and my Dell's and hopefully, it will be easier to setup than hex bar linkage.
Oh, don't mind the engine in the pic. It's just used for mocking up my parts. It doesn't even have any pistons in it
pete
pete
- Wally
Excellent work! tnx for the pictures
I am also a little afraid the rubber connection between TB's and manifold might give an inaccurate linkage (flex of the rubber hoses), but I can't tell how stiff the set-up is from here
Tnx,
Walter
Tnx,
Walter
- MattKab
Nothing feeble about that attempt!
Wally's concern would be almost eliminated with the proposed cable linkage.. a great idea
Did that rail in the mock-up pic come with those bodies?
1979 Karmann Beetle with 1.8ti T4 (still pastel yellow)
1970 411 Variant (black) daily driver
1964 lil' window Beetle (soon to be black)
