The new front stance ! shes a big one.
jwstevens
Any updates?
Post by jwstevens »
Any updates on this sexy beast?
Ribz
Post by Ribz »
looks sweet man! cant wait to see more
69bajakid
Post by 69bajakid »
I do have some updates :), things kinda slowed down for a few months due to me getting married and the guy with the buggy shop bought a new shop...so he had to move all the cars out and relocate to a bigger and better location. but things are still going on every day. all sorts of new work done to the motor..picked up a pair of FAT manifolds, and a new 40 IDF (i know its small but it was brand new and a smokin deal, same with the manifolds)..i have some KILLER 6X4 4130 Cro mo A Arms now, sorry for the shitty pics..im not much of a camera man.
the new arms hook up to stock IRS inner pivots. have bolt/weld on double shear heim mounts for the end of the torsion housing, they were custom built to have zero camber at 6" suspension lift (from stub to center of torsion tube)..they have a custom 4130 billet bearing housing that uses 930 type 2 stubs (short ones) runs a stock roller outer bearing, but uses a double ball bearing for an inner, like a FWD car would have.
the front end was redone thanks to the comments, i now have a double shear front shock mount system, i think it should get the job done..:)
as soon as the car gets back into the shop i can get the rear part of the cage done and the 2.5 Air shocks hooked up to the A arms, pop the motor back in...set the angel of the tranny mounts, and build the rear bumper cage...
its getting closer. i should have more recent pics very soon, i just got back from Hawaii so im a little behind on the baja stuff.
but here are a few pics for ya.
thanks for the interest!
that is before the new shock mounts, but at ride hight with the bumper.
thats what it looks like at short course race hight..if i jump on it i can get the bottom of the beam 3" off the ground.
here are zome wonky pics of the new front shock mounts.
the pics dont do any justice for these arms, they are huge..i fell in love at first sight with these babys. they were a smokin deal also, $435 bucks custom built..if anyone has interest i will send ya the shops number..its one guy that builds the arms, and one guy makes the bearing housing..perfect workmanship, even better value...and built to suit..he does all sorts of arms, not just these..
well, thats all i have at the moment..but new stuff will be online soon.
thanks again
Cale
Ribz
Post by Ribz »
nice dude! if you cold post that number or PM it to me that would be sweet! 6x4s are yummmy and is that $435 cdn or usd
i forgot if you mentioned this but are thoes the tweeds front arms? ill go back and read up
69bajakid
Post by 69bajakid »
Yep Tweeds 4X1 3/4" arms and 3" lifted combos with the king kong pins.
Dave Brown made the arms, he also made the set that ya see on the rear of the car in the pics, those are drop in 2 1/2 X 2 1/2 bus stub 4130 arms.
and now that i dug out the invoice.. i was wrong on the price.. the arms were a whoppin 400 USD, not 435. and with the dollar these days CDN and US is so close it dont make much differance..but the price is in US dollars.
His company is MUDDY RUDDER OFF RD. SP. in Gresham Orgeon.
his number is 503 658 8499
He gave me the ok to post his name and number, but if your gonna call just tell him you got the info from Cale, i still talk to him once a week about other parts so he knows who i am, and if you tell him you seen the pics of what i had..you will be ahead of the game if you want the same kinda thing..
Todd at prescion alloy makes the bearing housings.. they work together by the sounds of things.
thanks again for the interest.
Cale
MadDog
Post by MadDog »
cale
are you selling those 2 1/2 x 2 1/2 arms with the bus stubs, if you are I would probebly love to pick them up!
69bajakid
Post by 69bajakid »
Sorry but i already sold the arms and my old front end to a friend of mine.
he is putting them on his OG Manx buggy.
i paid around the same price for those arms as the new ones i just got.
i know you can still get them new.but thats about all i can do for ya, sorry.
thanks
Cale
findog78
Post by findog78 »
Holy balls...those arms look massive. Any idea how much they weigh compaired to a stock trailing arm?
Sweet Baja...
69bajakid
Post by 69bajakid »
i will have 2 dig up a stock arm, but you gotta compare them to a stock arm and a spring plate..as they act as both...and i bet ya they weight less than stock..they are not that heavy...i will toss one on the scale and let ya know.
Cale
64VW-T1
Post by 64VW-T1 »
Very nice Cale. Long time no speak as well.
69bajakid
Post by 69bajakid »
Hi 64VW, where do i know you from? sorry, but i dont recall..
Thanks for the comment though!
Cale
64VW-T1
Post by 64VW-T1 »
NO, you wouldn't know me under this name.
I used to be a baja guy, trying to get back into it now. We used to talk off and on through ICQ. Haven't heard from you in years.
69bajakid
Post by 69bajakid »
Well, let me know what your ICQ name was, i remember baja fleg, dragon, shamrock 81, eric from seattle, tony from point roberts...tons of ppl i used to talk 2 on ICQ about baja stuff,
let me know who you were i am sure i will remember!
thanks!
Cale
64VW-T1
Post by 64VW-T1 »
Cool. I'm #1, I'm #1, I'm #1!!!!!
69bajakid
Post by 69bajakid »
I finally got one of the new a arms installed on the car last night..
as usual..it was a little more work than expected..i thought i had the spring plates totaly un preloaded (torched off the stops) turns out they still had a lot of tension in them..no jack..no chain..tried a forlift..ended up using a hammer..
i had to cut my torsion housing down also..i cut the section off that would support the upper shock mount..and the body mount..i cut it off right along the line of the end cap. sawzalls come in handy at times...so lots of room for the arm to swing now....
im going back now to install the right arm..and take some pics...
its F!#$@!%G Huge!
Later
Cale
