So after replacing the gasket on my auto trans drain pan again I have come to the conclusion that it is probably warped and a new gasket just isn't going to do it (the area around each of the holes is warped as I suspect a previous owner overtightened it instead of replacing the gasket). Does anyone know a place where I can get a new drain pan for the auto tranny? I know it is the same as some bus auto trannys but no parts places I have seen have just the drain pan for sale. Any ideas/sources?
Thanks,
Kevin
Auto Trans drain pan
- ubercrap
You might also read this post that was in the Type 3 forums.
http://www.shoptalkforums.com/viewtopic.php?t=95911
I found this to be good info as my pan gasket seems to be leaking.
