Pics of CIS in a bay bus anyone?
farmer
Post by farmer »
I am about to do my first CIS install in a bay bus. Do any of you perhaps have some pics of "your" install, and care to share them with me. Then I would really appreciate it. That will help me to not having to invent braces and locations again.
You can put them here, if its ok with the moderator, or in my Email
I thank you in advance.
Torben
regis101
Post by regis101 »
IIRC, Jake Raby has CIS in his bus
This isn't going to help much, but the EFI bays have a really solid mount for the air cleaner.
The only major mount required for CIS will be one for the metering unit at that air cleaner location, such that the ouput hose hits the L-Jet S hose... (If you want ~100% factory parts, just from different vehicles)
An early Golf plastic air meter<>TB bit will probably work perfect.
The only other significant "mount" will be for the CPR<>Block, assuming you are using basic CIS.
I like the CIS-E fuel pump/sump/filter setups. Works fine with a facet as a feeder, at least at "normal" power levels.
I can send you pics of my 914 install, but the Bay should be FAR easier.
MASSIVE TYPE IV
Post by MASSIVE TYPE IV »
Any questions???
My CIS has not been touched with a wrench since 2002.
If the install was not so demanding on the installer and the CIS parts were more plentiful- I'd still offer CIS engines because they work so damn well.
Just wanted to say the facet as a CIS feeder was JAKES idea...
He uses it on the above install IIRC.
I am always delighted to borrow a good idea ;-)
farmer
Post by farmer »
Exellent. It was "that" picture of Jake engine compartement I had in my head, but just couldnt get it al placed.
One other thing. How did you make the jet holders ? Did you take something from another car, or did you make something up ?
Also, where did you mount the coldstart or choke feeler ?
Answers to that, or even pics, would be dandy.
thanx.
T.
MASSIVE TYPE IV
My holders were turned from Aluminum and welded into the manifold.
A friend of mine, No H20, who frequents the board did a CIS install a few months ago and he modified valve retainers to do the job with the stock clamps and it worked well..
PM him -I'm sure he'll share. He loves his CIS as much as I do
I made mine from 1/2" tubing and modded valve spring retainers, clamp in like L-Jet injectors. (another idea at least partially stolen from here) very easy to make.
can e-mail pics if you like.
farmer
Post by farmer »
Ok. Thanx to all. That gets me something to go for. No need to invent the wheel more than once.
Piledriver, I would appreciate a picture of your holders. - I´m the type of guy that sorta needs to see things once to be able to get my ideas, or even copy other peoples good ideas :oops:
Oh, well, now its out :lol:
T.
You've got mail.
