Thank you for all the responses!
The welder I have,
it has 4 tempature settings low 1, low 2. high 1, and high 2.
the wire speed is the dial. Now, this is simular to the Hobart that has 4 settings instead of two switches.(over $100.00 more with no regulator)
I understand its(my welder is a POS), but its the abosolue best I could afford under my present situation, in fact I have built a low 13 second vw drag bug with-out a welder of my own, mostly using nuts and bolts, etc.
this was a jump for me.
I will be doing a very limited amount of welding.
I was going to buy the Kafer cup rear strut-tower engine support brace for $265.00, Instead I bought this welder, so I could make one of my own, and then weld up the door jams so the doors stop sagging, etc.
Thanks again
are flux-core wirefeed welders any good
- bugninva
LOL...you will do *alot* more welding than you think you will....there have been thousands of times you needed a welder and didn't know it....you will find many uses for it, and i think every auto enthusiast(whether it be restoring or racing, or just "fixing") should have a welder...they are a very valuable/versitle tool...Bugzlife wrote:
radiobirdman32
I built my sandrail, my baja and my mid travel FG buggy with a Millermatic 130 XP using only flux core wire. I was doin alot of decorative fences and gates at the time so I was almost always outside in windy conditions(which render gas ineffective) and I was also hauling it around all the time so no bottle and reg = less weight. I recently upgraded to a gas Miller 210 and it is nice in the shop and for heavier material but I still use the 130 alot. The 130 runs on a 20 amp 110 circuit and has steel or aluminum drive rollers. I've never had a problem with it and have probably run 40 rolls of wire through it. I agree on the autodark helmet and put a lambswool liner on the headstrap. A welder will open up all sorts of possibilities if you like building your own cars.
- Bugzlife
I have been using the Welder more than I thought! I have a regualator but have only been using the flux core wire, seem to work ok for big guage stuff, as I can only get fluxcore wire in .30 and .35 size, for sheet metal I definatly need to go with solid core and gas .24 size.
next time I'd buy the HD100 by Lincoln
GjMan
I have the Lincoln Weld Pak 100, which is similar to yours--four heat settings and pretty broad wire speed range. It was flux when I bought it, but after struggling for a time, I spent the money on the gas attachment for it. I became an expert (well, practically) sheet metal welder overnight! Worth every penny.
- Bugzlife
I'm getting better with the welder, it takes time to get the temp setting and arc working good with out burning through the metal.
my wire speed is between 2-4 but never higher I have no clue how you can use wire speed over 5 its just way to fast?
I have the gas hook up and will get a bottle one of these days
love the welder,
need a ground= solution weld a bolt to the frame, put on ground strap and tighen nut, (no more drilling holes!)
love the welder,
snips77
They work !!
just practice practice and practice...Ive welded plenty of vws back together with a flux core welder, yes they do spatter thats why you have a grinder, yes you cant weld thicker metal, thats when i break out my stick welder...go for it man, ive been using a welder i bought from harbor freight for 97 dollars done heater channels , lugage rack fire wall door post in a 68 and suicide doors on another...Good luck
