Possible to make a "quick release" muffler for hideaway turb
langsen
Possible to make a \"quick release\" muffler for hideaway tu
Post by langsen »
I would like to be able to remove the muffler for special occasions -- like when my car isn't in the process of being inspected by the DMV.
Sharkey
Post by Sharkey »
I had a similar problem installing a muffler on my car. About all the space I had at the time was for a Supertrapp, and it doesn't help to quieten things down very much (95 dB). I'll be looking at installing something a little better this summer.
langsen
Post by langsen »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Sharkey:
I had a similar problem installing a muffler on my car. About all the space I had at the time was for a Supertrapp, and it doesn't help to quieten things down very much (95 dB). I'll be looking at installing something a little better this summer.<HR></BLOCKQUOTE>
I had considered this, but did not think the DMV would find it acceptable. Also, there are times when I might not want to have the loudest car on my block, and a real muffler would be a good thing. But, I will probably try the Supertrapp until I figure out a way to make a quick-release muffler.
Bobby74
Post by Bobby74 »
I have seen Baja style stinger setups that use springs to hold the "muffler" on the header... Mayble you could buy the stinger portion, (probably less than $30) and adapt your header to use the spring plate to hold it together. Weld your muffler of choice to the end of the stinger for a expansion chamber effect (like motorcycles, old racer's trick). Could this work?
just an idea,
Bobby
BergRace
Post by BergRace »
Take a look at a motorscycle with a slip-over silencer, same principle is easily adaptable, and you could use bolt goig through two welded on bits of narrow ID pipes to clamp it with.
J.
Steve C
Post by Steve C »
Hi
On autospeed.com they tested a exhaust butterfly. It was like throotle butterfly and on low throttle openings it almost shut reducing noise greatly, it has a control unit to help keep the noise down.
A friend of mine years ago had a thread on his tailpipe and to reduce noise he would screw on caps with different size openings. This was to pass noise tests for rallies.
I remember seeing y sections with a flap inside you could fit into your exhaust, one outlet went to open air and the other into the muffler.
Regards Steve C
