Oil Pressure drop off
Hi Guys,
I have a 2110cc motor in my bug its run in but i have only done about 15 miles on it, it has a CB oil pump and is full flowed to a remote mounted fram filter. there is a breather system which vents the case and the rocket covers.
Oil pressure is fine at start up and general running its about 30-40psi but when i floor it and give it some stick the oil pressure light comes on and the pressure drops right down to virtually 0psi does anyone know what this could be????
Thanks,
Rob.
Thanks,
Rob.
- Max Welton
- Max Welton
- Max Welton
- rcb78
Some filters have a check valve in them so they really only flow one way, AKA anti-flowback valve. Some does get through, just not enough to sustain rpms. Once the engine spins up, centrifugal forces throw the oil out at the rod throws and and have a tendancy to evacuate the system if insufficiant flow is present. So with a severly restricted oil flow, the pressure can drop as rpms rise. That's just a guess based on an observation from a guy I know. He had the same problem, albeit lower pressure to start with. But it dropped if he free revved it. Problem went away when he found his oil lines reversed.
The only time I've ever seen something like that happen is when someone is running severely low on oil. All the oil gets sucked into the system and you start sucking air when you bring up the rpms. I guess I made the assumption that he checked all the obvious stuff first. Sucking air at the pickup tube extension joint won't be that severe. You would just see lower than normal pressures in higher rpm range, not a drop. --Ryan
Ok heres the situation. The engine was prebuilt. I bought it in Longblock form. the sump is a deep sump that i was told when filling up with oil only fill to the lower dipstick mark? I have not checked the oil pickup tube, should it be right there when you take off the sump plate?
I know the Oil fittings are around the correct way to the filter as i did all that myself.
Thanks,
Rob.
Thanks,
Rob.
- Max Welton
Yes, the oil pickup is visible when the sump plate is removed. It is important that the end of the pickup tube be close to the bottom of the sump. The higher up it is, the more easily it can be uncovered due to windage at higher revs or during high-G situations such as hard cornering and acceleration.
When a deep sump is added to the engine an extension to the stock pickup tube is added to keep the intake at the bottom of the (now deeper) sump. Some extensions fit better than others and there are several ways to attach them (welding, brazing, clamping).
You should fill oil to the usual (top) mark on the dipstick. That's probably part of the problem right there.
Max
Max
Nah.. if that fixes it your extension tube is either missing, loose or has fallen off. I run my 2332 with the oil at the lower line to keep from slinging so much, since the crank adds about 7mm to the depth into the sump. Being too close to the oil's surface with the crank will cause a lot of turbulence to grab the oil and sling it toward #3 and #4 side, and that makes it harder for that head to drain its oil. If you have a sump, you can drop to the lower line and be ok. It's not quite a quart, and in my case, it's still 6 quarts of oil, or a little more.London Bugger wrote:Looks like I have been miss informed! I will top it right up and see if that makes a difference.Max Welton wrote:You should fill oil to the usual (top) mark on the dipstick. That's probably part of the problem right there.
Max
Rob.
