Does the flywheel need to be taken off to split an engine ca
TKisner
Post by TKisner »
Does the flywheel need to be taken off to split an engine case? If so why? thank you
DesiJae
Post by DesiJae »
Have you ever tried removing a flywheel without an impact and nothing to lock it to? Yes you can.
Odyknuck
Why leave it on
Post by Odyknuck »
If you need to split the case why leave it on? Its just more weight to deal with and you cant get the main bearing or the seal off.
Marc
Post by Marc »
Flywheel has to come off first on 36HP and older engines only.
http://www.shoptalkforums.com/viewtopic.php?t=82437
Brian Murray
Post by Brian Murray »
also on 356s theres a bolt right above the cam plug.
but then we dont drive 356s now do we? :lol:
Guest
Post by Guest »
The type 4 also has a bolt near the cam
Armand
