Harney's diatribe - rocker geometry to install & beyond
James Buchan
Post by James Buchan »
www.airspeedparts.com has a few of my welded fans on the shelf if you need a replacement.
mharney
Post by mharney »
Thanks James. I have a replacement coming for it. If it's crooked too (I doubt it will be), I will hit them up for one.
--Mark
Bugzlife
Post by Bugzlife »
Don Jiskra wrote:Fred Sanford Engine Stand
Why not?! that stand has got more reinforcement than the Brooklyn bridge! :D
mharney
Post by mharney »
LOL. I'd HATE to do the FBD on that stand.
Well, here is where I am at today. I am going to go ahead and run it in with the old fan, and then swap out for the new one when I get ready to install it.
Just got some details to take care of now, plumbing, linkage, etc..
Anyone as excited as me? How could you be?
James Buchan
I've never had luck with the oil fittings you are using for your full flow, might want to try this:
http://www.thesamba.com/vw/gallery/pix/172800.jpg
mharney
Post by mharney »
These are pretty much guaranteed not to leak with the hose that I have for them. If they do, I'll switch over before I put the engine in.
On another note, I just ordered my cut to length aluminum pushrods about two or three days ago, and they already showed up. John C is the greatest.
surfbug
Post by surfbug »
James Buchan wrote:I've never had luck with the oil fittings you are using for your full flow, might want to try this:
No worrys, I'm using that exact setup on my 1914, no leaks :)
matt
MNotary
Post by MNotary »
Is that "push-lok" hose? Nothing wrong with that as long as you use oil compatible. Plus no hose clamps needed.
[quote="mharney"]These are pretty much guaranteed not to leak with the hose that I have for them. If they do, I'll switch over before I put the engine in.
mharney
Post by mharney »
It's the stuff ACN sells. The blurb says the same thing, basically.
EASY RIDER
Post by EASY RIDER »
NearlyDeadZone,KS :lol: :lol: :lol: :lol: :lol: :lol: :lol: :wink:
Bert
mharney
Post by mharney »
So.. question:
Would NOT having a bushing in the bellhousing cause a starter to stick on and continue to run, and not want to disengage until I cut the main power?
Island bugs
Post by Island bugs »
mark seems reasonable to me if you are using a bushing type starter it could "@@@@" and stick. Wayne
mharney
Post by mharney »
It's on my engine stand.. It's a T2 bellhousing that should have a bushing. I just didn't have one and was lazy, so I tried to crank my engine over with it to make sure it was gonna work, and it stuck. It may be the starter too I guess, if it is sticky itself. I have another starter in my car that is basically new that I can try, but I will get a bushing first and see if that takes care of it.
Only a few details away now. Flywheel on, all oil gallery plugs and slugs in, just need to finish a little plumbing and get it primed, install the electric fuel pump and tank, run gas lines, install linkage, set up crankcase ventilation, install the ignition, install pushrods and rockers, and off we go.
sparkmaster1
Post by sparkmaster1 »
Good luck, Tim
Owner Tim's ACVW Engine/Trans Service
64 variant
Post by 64 variant »
Quit talking and start chalking!, get that bad boy up and running already!!!!!! :roll:
