VW Trike
VWLARRY72
VW Trike
I am in the process of turning a wrecked '72 Super into a Trike. I've been cruising the web looking for ideas and came across this site, http://hometown.aol.com/eretzelectric/C ... trike.html, he has used rigid electrical conduit for the frame of his trike. Any thoughts on this, is it stong enough, will it last. Real curious as to what others think. Thanks.
letterman7
Echo on Dave....bad idea. For anything that is going to be on the street, it should be a heavy wall aluminum or steel (better) frame, TIG welded is best. Conduit is too thin, bends waayyy to easy, and rusts if you look at it.
If you go aluminum, use T6061 and TIG weld it. Just don't try to bend it too far.
Rick
Rick
letterman7
Hmmm...looks pretty. Let's see how it fairs under load and pulling that trailer. Welding galvanized isn't easy. The only problem I see thus far is possible electrolysis from all the dissimilar metals used. Hopefully it's primed and painted and grounded correctly. Who knows? This might be the new way to build bikes!
- JC-ATL
- JC-ATL
Re: off topic
By The WayGomer_pyle wrote:what does btw stand for?
Guest
Actually that is what I'm doing on this fist trike. I'm keeping the entire bug pan, cutting off the frame head and welding on the front of an '82 Honda CB900 Custom that I picked up from a salvage yard for $100. Plan to sell the good parts of the bike on Ebay and get my money back. Just go to Ebay and do a search for Honda CB900 and you'll get about 5 pages of parts. Seems to be a market. But like I said this is my first trike, want to do something different next time. But I do appreciate all the input. Didn't think conduit was the way to go. Thanks again and I'll post some pictures when it's done, most likely next spring. Just like this year, got pulled off the project to paint the house.......
