big block bug?
bondjames85
big block bug?
I have had the desire to build a VW bug with a large big block motor for some time, it would require extensive fabrication, and ulitmatly it would end up being a dune buggy frame with a mid mounted v8 hidden inside a Bug. For simplisity I would probably use a solid rear axle, but if I feel ambitious I may try to use a Mustang Rear end or some kind of independant setup for better handling. Has anyone ever seen anything like this attempted, and if so, any comments or Ideas?
houseofghia
twoghias
Ken Lowe's friend Simon has a BLOWN v-8 in this one--->http://www.kenlowe.com.au/car42.htm
- Travis S
a good start point would be www.prostreetbug.com and it would be easy if you went front engine.
MASSIVE TYPE IV
- slowsixtyduece
- Searoy
- James2
Yeb, why not just go get a Rustang or Gaymaro and save the vintage VW steel for the flat Four freaks.
It's your money, so do what you like, just don't ecpect to get much respect from the aircooled crowd
slowsixtyduece wrote:No offense or anything, but i hate it when people put any other engine other than a falt four in their VW. Would you put a hi-po VW motor in a chevy nova? NO!! Stick with a hi-po VW engine in a VW! Please dont turn to the darkside!! My own opinion, though.....
Tugboat
MAN, I thought this was a CONVERSION forum. OOH, DONT DO THAT!
You might try a TH425 tranny, out of a Toronado or El Dorado. You'll need a simple adapter plate from Trans Dapt. Standard position will put the engine over the axle with the tranny behind. Some turn it around for better weight distribution. Look here:
http://www.fiero.nl/forum/Forum1/HTML/030268.html
Reggie Jackson used to have a Porsche with a mid mounted aluminum big block. The injector stacks stuck out the back window. AWESOME!!
GL
GL
- miller
Tugboat said it.
THIS IS A ENGINE CONVERSION FORUM. If you dont like engines other than a flat 4 aircooled in a vw then get out of this section of the forum. If the main poster cared about making a turbo flat 4 he would look at the turbo section.
As for the post I dont see how you could make is mid engine withought using a transaxle be it vw or porsche. So ok 3 options you got make it FWD wich means you have a TON of tranny and engine choices. You can make it mid engine and use a porsche/vw transaxle or do it fwd caddy style and have the engine mounted transverse. Or you can make it read engine and use the vw tranny. Personally I like the mid engine mounting with a 901 porsche tranny behind it or even the caddy transverse tranny. Keep us posted on what your ideas are.
