Aircooled wbx heads
Just left the Yamaha dealer.
The Roadstar 1600 is 95mmx~108 (stroke is approximate from memory)
the 1700 is 97xsame stroke.
The heads are 4 valve, pushrod, but use a single big tube, close together and use cross shafts for actuation, and the heads are mirror images.(Front/back)
As to the aircraft engine---If those are yamaha cylinders, the finnage is all wrong, the ones from the Yamaha factory fins are far fewer, thick, and relatively widely spaced.
The 1600(95) jugs are $340 US ea retail, the 1700s(97s) are $400 ea.
They get~ $100-135 a piston, JE or Venolia/Ross would still be cheaper/better.
OTOH of you could find a couple of wrecks, it would be interesting to try.
Type 5 Joe
- Wally
Thanks for inquiring so fast!
97mm sounds the right size from what I read. I would like to see those for myself.
I will try to get some more info from this side on what was actually used on the oxyboxer from GWD (Gerd Weiser Dusseldorf)
Thanks,
Walter
Thanks,
Walter
Type 5 Joe
I think the most value to be had is to bite the bullet, and have the studs re-located...
Type I 94's / C.B performance 044 Heads / Eagle Cams, lifters go into all of my combinations lately... This is a value which is hard to beat, once you do the math.
At least for a 1st motor... the nickies and other trick parts would be good to try after success with one Oxyboxer.. I Promise you'll learn some stuff on a first build.
These lessons become very expensive.. When you go for the exotic parts on a first build / make a mistake
I just scored 5 complete Core motors... I need a few more to do a Production run (10) of these cases.
I currently have two running, and 1 that will be about 2500cc in the works.
I have several in customer's rides, and a few more customer's that have yet to complete assembly... I'm doing a pancake version right now... It'll replace a Type III motor
-Or Type IV, He He
I'm sorry, Type IV's are heavy pieces of expensive Junk!
- Joe
-Or Type IV, He He
- Joe
I agree, for most NA apps, a straight T1/T5 setup is most cost effective/easy.
If you want >94 bore, or need water cooled heads...
Does anyone know anything about the late T1 cases?
Did they have the oil filter like a wasser?
Were they Aluminum or still mostly mag alloy?
Industrial motors?
(Still wondering about the block they use)
Most Germans I know speak better english than half the americans I know... I'll wait to see if ehy respond to you, Joe, I have some good German friends if you get nowhere. (They are unfortunately down south near Munchen)
Industrial motors?
Type 5 Joe
It's a Wasserboxer Case for Shure... All of the motors have VW cases and heads.
They do sell some obvious ACVW Type I based motors too... further down their product's page.
They certainly don't advertise that any of those motors are Volkswagen engines, anywhere...
I have seen every aftermarket case up to Date.. From the Deano, Pauter, Scat, Bugpack, ect... to the latest ones out of Brazil.... to the pent-roof design.. And the Type IV factory cases.
The only one I have not dealt with is the one out of Vancouver Washington, and the C.B. Performance one that was never released...
None have the same features as the Wasser / Oxy... NONE
Still waiting for a responce from them, I doubt if they'll respond for some reason...
- Joe
- Joe
Type 5 Joe
I'm dubious these are Wasser blocks... The oil capacity is listed as 3.5 l.
Thought the wasser was 4.0L (4.2 qts)
I have read of "late model" T1s with spin-on oil filters and Hyd lifters---
I would almost bet these are those blocks.
The sumps don't look deep enough, bit hard to tell in the pic.
The "1700" series are DEFINATELY T1 blocks, 2.5 l oil capacity.
Or I could be wrong.
All their motors cylinders have the same heavy finnage, same style/location of cut away fins, 88s or 97s...
If I am right, a wasser would still be the better block by far, but I'm interested in their PARTS.(heads/jugs/pistons)
Type 5 Joe
- Richie
Hello,
Considering motorcycle cilinders, 2 types spring to my mind:
Ducati 1000DS 94mm bore x 71,5mm stroke, but only the top cilinder, because the finnage of the lower cilinder is totally wrong and the other could be a Yamaha BT 1100 Bulldog 95mm bore x 75mm stroke.
It seems these can be used but I don't know their prize but I think it will be in the near the cost of a set of Nickies. Then you'll have to make them fit. I doubt if they are worth the effort, but then again, time is often free
Cheers,
Richard
Cheers,
Richard
Guest
I glad you're sorry about that! hehe.Type 5 Joe wrote: I'm sorry, Type IV's are heavy pieces of expensive Junk!
- Joe
If you want more than say 2,4 ltr for a street application, the type IV is the ONLY way.
Pile,
The VW magnesium case with the spun-on oil filter mounting you referred to, comes from the 1600 vanagon (type 3 bus) that was build roughly around '79-81 when the type 4 2 liters (CU prefix) were the alternative. In Europe, these cases have a CT prefix and indeed run hydro's as did the 2 liters at that time.
Greetings,
Walter
- Wally
Sorry, the above was me. Damn logon. It used to be automatic..
In addition: Joe, I also think that the wbx is the best stock VW (and most if not all others) case from an engineering point of view.
From a High performance point of view however bigger IS better! Funny, that I should tell you americans this haha.
Application decides which case you need IM(not so)HO.
Best regards,
Walter
Best regards,
Walter
Actually... a wasser can be (relatively) be easily built to 103x82+, the deck height starts getting interesting after that.
(The Oettinger/berg 103 jugs are unobtainium, tho)
You are right , though, the 103s are not viable air cooled on a wasser block, but a long stroke (to 90mm IIRC, cheby journal) is doable.
The only thing limiting T4s is the heads... (I guess the same could be said of big wassers)
Type 5 Joe
Wally,
Actually, You can build an 82 X 94 motor for only $500.00 more than the base price of a regular Oxy Conversion...
Even if you spent $1500 on a custom forged Wasser Crank (up to 90mm stroke), you would be doing the project for far less than a comparable Type IV.
No special fan shroud is needed ($500.00 - $800.00, no special exuast ($1000.00 for a good one) No need to replace the seats in the heads... I could go on.. There are alot of special parts / knowledge needed to do a Type IV Correctly
If the average person could have someone like Jake do a motor for them, or someone with his kind of experience... This would be a way to go.
The beauty of this conversion is that someone with reular Type I engine building experience can do one successfully... And for a more reasonable price.
Cams, lifters, heads, everything is available for these from the Type I market.. even CNC ported Heads, ect...
I'm shure you could do a Type 5, with the most expensive parts available... and still have a motor that would out-perform, weigh less, and out-live a comparable Type IV... for less $$$
The best part is the driving characteristics.. You can have a motor with bottom end torque... and top end.
A big Type IV has a different feel... They are a Torque motor
This is why hardly anyone Drag races the Type IV...
- Joe
Wally,
- Joe
- Wally
I just got a message back from Gerd Weiser from Germany, who occasionally builds high end oxy engines for customers:
They CAN supply the Limbach twin spark heads with the wbx stud spacing!!
That info is not on their web-site of course: www.GWD-weiser.de
Either as a raw casting or totally machined with valve guides and seats.
Raw casting set costs ? 464,-- and complete machined costs ? 1000,--. The machined version is without any porting work done tho.
Also piston/cylinder sets can be had for the wbx stud spacing: I think they are Alu/Nikasil: 96mm costs ?1.100,-- and 97mm is ? 1.716,-- a set.
So there you have it.
Greetings,
Walter
Greetings,
Walter
