Wally
Posts: 4564 Joined: Mon Oct 28, 2002 12:01 am
Post
by Wally » Wed Jan 14, 2004 8:16 am
Hi Jake,
In your testing, what gave higher EGT's : engines with higher compression ratio or the ones with lower CR?
Thanks,
Walter
MASSIVE TYPE IV
Posts: 20132 Joined: Fri Jul 07, 2000 12:01 am
Post
by MASSIVE TYPE IV » Wed Jan 14, 2004 8:29 am
without a doubt- Lower CR.
Higher CR gets the fire started and over before the exhaust event ever begins. Low CR pigs still have a burn occuring when the exhaust valve begins its event.
Inefficiency kills EGT.
Wally
Post
by Wally » Wed Jan 14, 2004 10:29 am
Thanks, makes sense.
Walter
Guest
Post
by Guest » Wed Jan 14, 2004 12:13 pm
What EGT range is the most HP usually made at?
Kevin
MASSIVE TYPE IV
Post
by MASSIVE TYPE IV » Wed Jan 14, 2004 12:28 pm
I set mine to run 1150 or so at wide open throttle with a 75BHP load...
