where can I get 'em?
are they worth it?
I have the big and small rockers
any special setup?
tia,
K
911 adjusters
911 adjusters
I can supply a 3 sets out of my stash. Steve
- Tom Notch
911 adjusters
The Berg swivel foots work very well and are a lot less money. And again just the 8mm rockers. Take about .060 or so off the bottom of the rocker so the adjusting screw will travel up into the rocker a bit farther so as to off set the added length and it will be easier to set up your geometry. Even FAT will mention this little tidbit.
Tom Notch
Tom's Old VW Home
Tom Notch
Tom's Old VW Home
- Bleyseng
911 adjusters
I also run the Berg swivel feet with the 1.7 rockers. Also, swap out the springs on the rocker shafts for the solid spacers off a Hydro valve rocker set up. This keeps the rockers in place with no chance of them slipping around.
Geoff
76 914 2.0L
Geoff
76 914 2.0L
911 adjusters
I haven't purchased anything from Jim, but I saw on his Web page that he sells the 911 adjusters..http://www.geocities.com/motorcity/9008/parts8.html
- Tom Notch
911 adjusters
I didn't say FAT used Berg adjusters, I said they will tell you to trim the rocker if you use them. Just don't want any mis-understandings.
Tom Notch
Tom's Old VW Home
Tom Notch
Tom's Old VW Home
