I am building my first stroker motor i have
new as-41 case
82mm bugpack crank
i-beam rods bugpack
44mm idf webers
90.5 pistons
my question is what grind cam do i need for a drivable street motor right now i have a set of new 041 heads but i am considering seriously about the cb 044
i have a question
- turboblue
Be prepared to notch your camshaft with I-beam rods. I am putting together a 2110cc with Scat I beams (similar to yours) and had to notch the cam rather severely. Looks like the end of a set of Lincoln Logs now. (for those of you thats old enough to remember them). Had always used H beams before with no problems. Used a new CB super case and had to do some clearancing beyond what they had done in the roof of the case too.
Camshaft, I'm using an Engle FK 7 and Scat 1:4's on this engine and CB 044 heads w/40 x 35.5 valves. Dual 44 IDFs for induction. Will see how it runs when finished. Going in a customers '69 Baja.
Good luck.......
Good luck.......
