If I was to do a spot job on some rust in my raingutter and use rattlecans of gloss black and then clear over it while color sanding after every coat then a MAJOR buff job would the colors match fairly well?
Whole car is gloss black, color sanding the decklid that i had to do this weekend, if this turns out well then I might just do the above anyway.
rust is in front of door hinges, at the joint between decklid and body, and in rain channels.
a little bit on the front end too...
Any help is appreciated.
