steering gear mounting clamp orientation
VW's aircooled mini SUV. Great for riding in the country, or cruising the beach.
germansupplyscott
Post by germansupplyscott »
thingers,
i am remounting the steering gearbox on my thing after restoring the front end. in the manual i have (haynes beetle/ghia) it refers to the steering gearbox clamp having two orientations, one for beetle and one for ghia. the bracket has markings "13" and "14" on it.
which one points forward on a thing, "13" or "14"?
scott lyons
Marc
Post by Marc »
Good question, since a Thing is basically a `Ghia pan - I don't recall but I'd be willing to bet it goes on in the "Beetle" position, since the Thing steering column/wheel don't mount as low as in the `Ghia. It'll be obvious if it's wrong, the steering box input shaft won't be in line with the column.
germansupplyscott
marc,
the vehicle is not assembled yet, so i have no way to check the column to box alignment. i can attach the gearbox at a later time, but it is so much easier to do it all now.
scott lyons
Marc
Post by Marc »
punkinfair wrote:...the vehicle is not assembled yet, so i have no way to check the column to box alignment...
Oh. I'm pretty certain it needs to be in the "Beetle" (higher) position so that's where I'd put it unless someone who knows otherwise comes forward.
germansupplyscott
marc,
that makes sense to me.
scott lyons
