strengthening the exhause port?
Black69Bug
Post by Black69Bug »
i called aj sims yesterday and he mentioned something to me about strengthening the exhaust side of the stock cylinder heads. does anyone know what he is talking about, because im not exactly sure what he ment
-Kevin
1fasbug
Post by 1fasbug »
I have read that people remove the exhuast valve guide. i guess they can crack and suck into the turbo or cylinder. if you look on CLF under head porting it shows the heads minus the exhuast guide.
69bug
Post by 69bug »
BOSS!!!
vtecthis
how does removing the valve guide...
Post by vtecthis »
How does the removal of the exhaust valve guide strengthen it? If you are not running that much boost (no more than seven) then you do not have to remove it. I think its removal causes shortened valve life. I have run seven pounds with the exhaust valve guide in place without any problems. Since I am turning the boost up to 15lbs I think I should remove the valve guide just for safety. I have to change the rings and lower the compression even more. I have a fairly thick head gasket, but the compression is still pretty high.
oh well, anyway, have fun with the turbo xperience
