Cam Duration and Lift
KGMAN
Post by KGMAN »
I bought a longblock from a guy (2016cc Stroker) but he cant remember what size cam he used as it was built 3 years ago. He "thinks" its a bugpack 110 ?? I Need to know how to determine cam lift and duration. Hopefully someone knows how this is done..
I plan on using the CB FI Kit and need to know the cam specs so they can provide the correct injector size.
Thanks for your input on this
Mark the canuck
Post by Mark the canuck »
the 110 cam is made by engle your cam may be a copy, short of spliting the case you would have to make a dummy push rod and hook up a measuring device, to much lift for a dial indiacator a set of calipers? and record the lift at the cam and the duration, sorry no simple way.
findog78
Post by findog78 »
Normally there is an ID code stamped in the end of the cam, which is visable when the oil pump is removed. Might be a simple solution. Good Luck.
ppp
Post by ppp »
MPMI on the end of the cam mean anything to anyone? thanks..Mark
stkrmtr
Post by stkrmtr »
mpmi--makes cam blanks in japan-All the cam companies use them engle web bugpack-thats why its so funny when people say web cams don't go flat they are made better that engle
Marc
Post by Marc »
There's more to grinding a cam than just the blank you start with. How it's ground and heat treatment, lobe profile, and the lifters' characteristics all matter too, so it's quite feasible that there can be different results even though the same casting is used by all. One of the biggest factors is breakin procedure and valvespring selection, too, so if the guys who like Webs are the same guys who do this part right, of course they'll last longer.
Some people can break a crowbar in a sandbox.
"For every complex problem, there is a solution that is simple, neat, and wrong." --H.L. Mencken
`67, 69, `77 Beetles, `73 II (Type I engine), `86 Audi 5000s, etc. etc.
Independent VW specialist shop manager/unit repairman 1978-1991
Lots of good links in my Yahoo! Briefcase
http://briefcase.yahoo.com/marcvellat
JohnConnolly
Post by JohnConnolly »
If you've ever degres in numerous Web and Engle cams, you'll see that all cams are not created equal. It's not at all uncommon for Engle to be off by 4-5 degrees, I've never seen a web off by more then 1/2 degree from the card.
What does this tell you about attention to detail?
John
