I also have this posted in the bus barn since it's a Vanagon engine
For now I plan on keeping this engine stock, except for changing the muffler... Should I get a progressive carb and intake or use the factory EFI setup?!? What would be the pro and cons of each?
FI or Carb
- Tom Notch
FI or Carb
Progressive carbs are JUNK! A stock EFI system is better as long as it has been maintained.
Tom Notch
Tom's Old VW Home
Tom Notch
Tom's Old VW Home
FI or Carb
The cons of the carb are many.
You WILL drop seats for starters; the manifolds are junk and don't meter equally to each cylinder.
You just threw your resale out the window.
You can't pass an E-test.
No E-test, no registration, in most states.
Increased fuel consumption.
Reduced drivability.
FI or Carb
I failed to mention that its going in a baja... They set me straight in the bus barn... EFI would be very hard to maintain in an open engine compartment... Looks like I'm gonna have to get dual carbs...
