Sealing an engine case?
74EMPI
What is the best product to use for sealing the case halves. I thought this was discussed previously but my search didn't turn up the thread. Thanks!
- Eaallred
Gasgacinch is sweet, but I have a helluva time finding it local.
i've used Permetex "Super 300" with good results also.
Eric
64 Bug
64 Bus
Eric
64 Bug
64 Bus
- Marty
Curil is the best stuff. It does not dry and seals perfectly.
Marty Staggs
www.staggsracing.com
Marty Staggs
74EMPI
Where would I find gasgacinch or curil. Pep boys, autozone????
melbatoast
anybody ever try the Black RTV? this stuff is used by some of 'the big 3' in place of actual gaskets; i.e. diff covers, etc.
arlan
you see these?
they are my carkeys.
you will never get these.
arlan
you see these?
- Marty
Do NOT use any kind of RTV or silicone on the case halves.
You can find Gaskasinch at Pep Boys and Curil from Berg.
Marty Staggs
Marty Staggs
rich2481
RTV is too thick, the cases are or should be matching surfaces. I use Permatex High tack, is like contact cement,
MASSIVE TYPE IV
Loctite 518......or Curil K2
Jake Raby
Raby's Aircooled Technology
www.aircooledtechnology.com
Jake Raby
max, Der Bahnstormerz
I use Wurth engine sealant on the case halves and Elring Dirko S on all the rubber seals, and Wurth hi temp scilicone at the barrel bases
britegreenVWSB
Permatex Forms-a-Gasket is what I always use. Otherwise known as Aviation Sealant. A VERY thin coat is all that is needed.
TG
TG
Milt Damnit
i like the k-2 curil or the permatex i think it's the 3H or part # 80019. both of these are a semi drying sealant that will push out of the case halves and allow them to seal to each other.
i don't like to use RTV because it will begin to dry and lump up and actually prevent the case halves from sealing to each other properly.
just my 2 cents worth
MASSIVE TYPE IV
afew years ago I quit using permatex aviation, after I realized it was only good for 1200 hours, then it starts to seep..1200 hours is one helll of a long time, but when my 200K engine in my 62, 15 window started seeping I knew it was true.
melbatoast
black RTV is out! :~)>
arlan
you see these?
arlan
you see these?
