Type 1 Wedgemate Crank into 2.1 WBX Case
Type 1 crank into 2.1 WBX Case - Possible?
Poll runs till Tue Mar 31, 2026 8:09 pm
Yes
1
100%
No
0
No votes
Maybe
0
No votes
Total votes: 1
23split
Post by 23split »
Searching for information or main bearing guidance to fit an 88mm Wedgemate Crank and flywheel into an 2.1 WBX Case for a 4" bore engine build.
I have read many posts but nothing has clearly identified which bearing to use.
I'm sure we can figure it out, but if someone here has already done the exercise it would be great to follow their lead.
Otherwise, I'll start the conversation and hopefully compile the answer for anyone who considering fitting a Type 1 crank into a WBX crankcase.
Have access to and the skillset to do almost any crankcase machining that might be needed so shouldn't need to outsource help in that department.
Let's get the conversation started.
List of bearing sizes attached
Bruce2
Re: Type 1 Wedgemate Crank into 2.1 WBX Case
Post by Bruce2 »
Better would be to have the WBX crank stroked to your needs so you can use a stock bolt-on flywheel.
23split
Post by 23split »
Thanks for that suggestion Bruce2.
It would be great to do that and take advantage of having the matching sized and the Wesserboxer flange style flywheel, but I already have this 88mm Wedgemate crank, the Chevy rods, the case and a bunch of other parts I'm attempting to use in this build.
Have you built a Oxyboxer yourself?
Keen to hear any experiences you can share.
Cheers
23split
Post by 23split »
Had a bit of luck regards main bearings and should be able to utilise genuine/standard VW crankcase bearings. No need to machine case, grind the crankshaft or modify bearings by other manufacturers or engines.
Rod bearing will be standard Chevrolet big ends.
Even found a rear main seal that should work without needing to fabricate any adaptor rings.
Will go do the assembly once these parts arrive from CSP, and if they work as expected we'll post all the part numbers we used. 🤞
Meanwhile, Hoover oil mods completed and clearancing for the 88mm stroke crank and Chev rods will commence.
23split
Post by 23split »
Photos 😁
23split
Post by 23split »
Photos 😁
23split
Post by 23split »
And more photos
H2OSB
Post by H2OSB »
Sure are pretty looking cases
I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. :wink:
23split
Post by 23split »
H2OSB wrote: Tue Apr 15, 2025 3:42 pm Sure are pretty looking cases
Vapour blasted.
Does clean them up very well 🤙
23split
Post by 23split »
WBX crankcase clearancing for it's 88mm Type 1 crankshaft has commenced :wink:
Will need 2-3 millimetres removed wherever the red ink marks the 'spot'
23split
Post by 23split »
8)
