Bruce.m wrote: ↑Fri Apr 19, 2024 6:32 am
Not an expert but the theory is that when you hit the spring’s resonant frequency they bounce around & lose control. The typical Scat single spring is good to 5.5k apparently, which I didn’t think was really worth it since stock T4 has 5.6k red line? The Scat single is 121lbs closed and 232lbs open @ 0.51”
The JPM spring that CSP sell is lower pressure than a Scat single but presumably has higher resonance? 109lbs closed and 187lbs open @ 0.53”
Stock type 4 is 104lbs closed and 191lbs @ 0.33”
(All those figures are from CSP)
When the springs are compressed (by the cam lobes and the rest of the assembly) there
could be some bouncing around, but I would suspect that the RPMs at that speed probably there isn't time for much of it. When the push rods and parts are at the bottom of the lobe there could be some bouncing around at higher RPMs.
I have not kept up with engine component designs for several years now, but from what I hear and see, things are changing in the cam designs and components about as fast as it did starting roughly in the late '30's/'40's and in the later directions. Which means that there can be... OH YEAH! and AW $HIT out there for sale too.
Materials and designs change quite a bit, say from round springs to flat metal springs and then the combining the two together for instance. The Beehive design has been around for a while but I am not sure for how long ago it got into engine design.
I got talked into a couple of things that, while they did work, it was to where the "brag about them" ended up.
If I remember correctly the flat springs were added to the assembly to stop the bouncing of the springs.
If I remember correctly the "Beehive springs" are progressive in their action. I did a search and found this:
https://www.bing.com/search?q=are+beehi ... de&pc=LCTS
